How do I creat a folder in the sd card with today's date as the name of the folder
I am trying to creat a folder with today's date as the name of the folder, the esp32 will get the date from a GNSS receiver. Inside the folder creat, the esp32 will creat a .txt file and I want to name this file with the current time of the day.
I've tried doing it like this:
void createDirectory() {
  Serial.println("");
  Serial.println("Creating directory");
  // if the folder already exists, don't bother creating it
  if (!sd.exists(Date)) {
    // attempt to access the root directory information
    if (myDir.open("/")) {
      // Create a new folder called 'testFolder'
      // mkdir will return true if it completes successfully
      if (sd.mkdir(Date)) {
        Serial.println(F("Created 'Folder' successfully"));
        Serial.println("Create 'Folder' failed");
      Serial.println("Open 'Folder' failed");
    Serial.println("Folder 'Folder' already exists!");
void GetTime(){
   if (millis() - lastTime > 1000)
    lastTime = millis(); //Update the timer
    long latitude = myGNSS.getLatitude();
    Serial.print(F("Lat: "));
    Serial.print(latitude);
    long longitude = myGNSS.getLongitude();
    Serial.print(F(" Long: "));
    Serial.print(longitude);
    Serial.print(F(" (degrees * 10^-7)"));
    long altitude = myGNSS.getAltitude();
    Serial.print(F(" Alt: "));
    Serial.print(altitude);
    Serial.print(F(" (mm)"));
    byte SIV = myGNSS.getSIV();
    Serial.print(F(" SIV: "));
    Serial.print(SIV);
    Serial.print(myGNSS.getYear());
    Serial.print("-");
    Serial.print(myGNSS.getMonth());
    Serial.print("-");
    Serial.print(myGNSS.getDay());
    Serial.print(" ");
    Serial.print(myGNSS.getHour());
    Serial.print(":");
    Serial.print(myGNSS.getMinute());
    Serial.print(":");
    Serial.print(myGNSS.getSecond());
    Serial.print("  Time is ");
    if (myGNSS.getTimeValid() == false)
      Serial.print("not ");
    Serial.print("valid  Date is ");
    if (myGNSS.getDateValid() == false)
    Serial.print("valid");
    long day = myGNSS.getDay();
    long Month = myGNSS.getMonth();
    long Year = myGNSS.getYear();
    Date = (day, Month, Year);
and also like this:
  Serial.println("");
void GetTime(){
    Serial.print(SIV);
    Serial.print("-");
    Serial.print("-");
    Serial.print(" ");
    Serial.print(":");
    Serial.print(":");
    Date = (myGNSS.getYear()) + '-' + (myGNSS.getMonth()) + '-' + (myGNSS.getDay());
That is not a complete sketch. What is the Date variable these functions are using?
the complete sketch is kinda big, so I thought I should only post the important part.
Sry, I forgot to tell what variable it is.
the variable "Date" is a String.
.mkdir() is expecting a C string ( a null terminated array of char) not a String object. Luckily, the String class offers a pointer to the underlying string: c_str()
sd.mkdir(Date.c_str());
I suggest using a string (== char array) instead of a String.
char date[11];
sprintf(date, "%04d-%02d-%02d", myGNSS.getYear(), myGNSS.getMonth(), myGNSS.getDay);
yep, worked like charm. thanks a lot
