I would like to read out 6 sensors and get a datafile. This file I would like to use in excel for analysis. But in the code I use numbers are splitted by a "," in a string and when copying this to excel it do not become nice columns with sensordata... I have now done it in a bold way by separating each value by a println, but I think it can be more nicely done. Who helps!
(I am not experienced at all, stil learning)
// make a string for assembling the data to log:
String dataString = "";
// read three sensors and append to the string:
for (int analogPin = 0; analogPin < 6; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 5) {
dataString += ",";
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
Excel can be told to use different separators when reading text files. The comma is quite common - the csv extension stands for comma-separated values - and excel can read csv files.
The character '\t' will put a tab in the file wherever it is used.
dataString += String(sensor) + "\t";
Not necessary to add the TAB conditionally => it would just give an empty colum in Excel.
Furthermore you could put the writing to file in a separate function: e.g. void LogData(String s) so it can be reused
e.g. from setup() where you could send a headerline to the log file so it is clear what the columns mean
