I'm an undergrad student, and I need some help finding a working code to make my 3D Cube actually walk in a commanded direction using DC motors, a shield, flywheels, brakes, and a Bluetooth chip. My partner and I have searched around for over a month now, but we are having some issues creating a compiled code.
You certainly do not give much to go on, so I'm not surprised you are having trouble.
What processor does the cubli have?
How might the processor be programmed?
Have you written any code at all?
You might take a moment to read the "how to post" sticky.
My partner has the code, otherwise I would have posted it. His code works, as I met with him today. We're farther along than I had mentioned, but I appreciate the replies. I apologize for cross-posting, I didn't know how to delete the former, so thanks for removing it. Thank you for the input everyone, I think all is going well now.
Arduino Uno
DC Motor Shield v2
DC motors, and hand built flywheels using steel washers as our guide
We intend to use an orientation sensor to read the errors; it will self-right itself to start position if it falls in the wrong direction. We're using the motors and flywheels to run a high speed and brake to get the cube to "walk."
Just in case anyone is curious since this was asked.
Sounds interesting, torque control like they use on some satellites.
It would be eerie to watch a cube jog, slide itself across the floor.
Keep us posted, and use the Exhibition section of the Forum to post your final result.
