I am doing a tiny project that detect status of main power,
Basically i want to send a sms once main power is down, so far i came to a point that able to detect status of power and send the sms
But there is a problem, sending the sms keep repeating itself until power comes back on. i wanted to design it one sms once power down and no sms when power comes back on.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(9, 10);
char msg;
char call;
pinMode(2, INPUT_PULLUP);
pinMode(13,OUTPUT);
mySerial.begin(9600); // Setting the baud rate of GSM Module
Serial.begin(9600); // Setting the baud rate of Serial Monitor (Arduino)
Serial.println("GSM SIM900A BEGIN");
Serial.println("Enter character for control option:");
Serial.println("h : to disconnect a call");
Serial.println("i : to receive a call");
Serial.println("s : to send message");
Serial.println("c : to make a call");
Serial.println("e : to redial");
delay(100);
{ int pushButton = digitalRead(2);
if (pushButton == HIGH)
mySerial.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
mySerial.println("AT+CMGS=\"+60XXXXXXXXX\"\r"); // Replace x with mobile number
mySerial.println("sim900a sms");// The SMS text you want to send
delay(100);
mySerial.println((char)26);// ASCII code of CTRL+Z
digitalWrite(13,LOW);
if (Serial.available()>0)
switch(Serial.read())
case 's':
SendMessage();
case 'c':
MakeCall();
case 'h':
HangupCall();
case 'e':
RedialCall();
case 'i':
ReceiveCall();
if (mySerial.available()>0)
Serial.write(mySerial.read());
void SendMessage()
delay(100);
void ReceiveMessage()
mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to recieve a live SMS
msg=mySerial.read();
Serial.print(msg);
void MakeCall()
mySerial.println("ATD+60XXXXXXXXX;"); // ATDxxxxxxxxxx; -- watch out here for semicolon at the end!!
Serial.println("Calling "); // print response over serial port
void HangupCall()
mySerial.println("ATH");
Serial.println("Hangup Call");
void ReceiveCall()
mySerial.println("ATA");
call=mySerial.read();
Serial.print(call);
void RedialCall()
mySerial.println("ATDL");
Serial.println("Redialing");
