How do I find a small touch screen sensor?
I need small sensor panels(Ideally multiple sizes from 1x1 cm up to 3x3 cm to experiment lil bit). It should be just sensor panel, without a display. Maybe I'm using a wrong wording to google, but I can't find anything. Supporting libraries aren't necessary.
I don't know what "sensor panel" means, either. Can you better describe what you want? Or make and post a picture?
groundFungus:
I mean a panel which can detect you pressing it and output coordinates where you pressed it, pretty much like in any smartphone.
So you mean a touch screen sensors? Like these?
groundFungus:
Yeah, exactly(edited the title). But the ones under the link are too big, the smallest one is 62.41 x 30.41mm which doesn't meet my criteria
Well, now you have a search term. That is just the first one that I found.
You don't need to present the entire panel to the user, use a panel cutout to expose only part of it?
MarkT:
There should be separate panels for each finger, so, no
Do you need to know the position on the panel that the finger is or just that a finger is touching. Maybe what you need is a capacitive touch switch?
groundFungus:
Yes, I do need to track the position
OK, I thought that I would ask as touch switch sensors can easily be home made in about any shape and/or size.
