How do I get a script to turn on a strobe light via USB
Hello,
I am really at a loss how to do this so would appreciate any advice. I use Splunk and within it you can set for a script to run when an alert happens, so what I want to do is when an alert happens for a strobe light and a siren to sound.
I haven't got a clue what kit is needed or the spec to do this? I suspect it will be some kind of a USB relay and obviously a strobe light and siren. Not sure how it should be wired up, I guess mains power (240v) to the strobe/siren positive and the negative connections to the USB relay? Then the scripting is there any free/sample scripts anywhere that can be used?
Thanks for reading
Guy
Yes, there are. Plenty of them are supplied with the Arduino IDE, and more are available on the playground.
What is a USB relay?
I use Splunk
What is Splunk?
do you have a link?
robtillaart:
What is Splunk?
do you have a link?
Here you go
http://bit.ly/GAdBBf
