Hi I am very new to arduino and processing and just about understand the basics. I have a school project and I just cant get my head around it. I am using Arduino Uno
I want to use an Accelerometer (3-5V GY-61 ADXL335 Module 3-Axis Analog Output Accelerometer Angular Transducer) to control a simple processing game. So instead of the mouse curser I want the Accelerometer to control the game by tilting left and right.
This is the arduino code I uploaded to the board;
const int groundpin = 18; // analog input pin 4 -- ground
const int powerpin = 19; // analog input pin 5 -- voltage
const int xpin = A3; // x-axis of the accelerometer
const int ypin = A2; // y-axis
const int zpin = A1; // z-axis (only on 3-axis models)
// initialize the serial communications:
// print the sensor values:
Serial.print(analogRead(xpin));
// print a tab between values:
Serial.print("\t");
Serial.print(analogRead(ypin));
Serial.print("\t");
Serial.print(analogRead(zpin));
// delay before next reading:
delay(100);
And here is the processing code that I am using - its a very simple game, move the penguin to overlap as many fish as you can.
int numfish = 3; //number of fish you want in the game
fish[] fishArray; //array of fish
PImage bg; //background image
PImage jf; //fish image
PImage sb; //penguin image
int fishSize = 50; //size of target fish
int score = 0; //current score
int timeLeft = 1000; //duration of each game (app. timeLeft / 100 in seconds)
boolean gameStart = false; //if true, game is in progress
PFont Font; //declaring the font used in the gameplay text
int endOfGameDelayCycles = 300; //how long the end screen lasts
boolean endScreenActive = false; //is the end screen currently showing? true if yes
//setting up the game, this only runs once
size(900, 700);
noCursor();
//initializing the array
fishArray = new fish[numfish];
for (int i = 0; i < numfish; i++)
fishArray[i] = new fish();
//loading the images
bg = loadImage("background.jpg");
jf = loadImage("fish.png");
sb = loadImage("penguin.png");
//this is the loop which will keep running again and again until you stop playing
void draw() {
background(bg);
textSize(11);
//start game menu
if (gameStart == false) {
fill(255);
ellipse(460, 300, 500, 500);
fill(0);
textSize(30);
text("Press 'A' to start", 220, 300);
if (keyPressed) {
if (key == 'a' || key == 'A') {
gameStart = true;
//while the game is on, between the start and end screen
if ((gameStart == true) && (endScreenActive == false)) {
fishArray[i].drawfish();
movepenguin ();
fill(0);
textSize(15);
text("Score: " + score, 20, 20);
text("Time Left: " + timeLeft/100, 200, 20);
//end screen
if (timeLeft < 10) {
endScreenActive = true;
fill(255);
fill(255);
fill(0);
textSize(30);
text("Well Done! Your Score is", 300, 300);
text(score, 450, 450);
endOfGameDelayCycles--;
if (endOfGameDelayCycles < 5) {
timeLeft = 2000;
gameStart = false;
score = 0;
//this function moves penguin when called
void movepenguin () {
//put the penguin image on the screen
image(sb, mouseX, mouseY, 190, 153);
//check whether penguin is overlapping any of the fish, if so, add the score and delete the fish
for (int i = 0; i < numfish; i++) {
if ((abs(mouseX - fishArray[i].getXLoc()) < 35) && (abs(mouseY - fishArray[i].getYLoc()) < 35)) {
fishArray[i].setLifeStatus(false);
fill(224, 27, 96);
score++;
timeLeft--;
//create a fish object
class fish {
//x location, y location, how long it will stay on screen, dead (0) or alive (1)
float xLoc, yLoc, lifeDuration;
boolean lifeStatus;
fish() {
xLoc = random(fishSize, width - (fishSize + 10));
yLoc = random(fishSize, height - (fishSize + 10));
lifeDuration = random(25, 100);
lifeStatus = true;
float getXLoc() {
return xLoc;
float getYLoc() {
return yLoc;
void setLifeStatus(boolean tempLifeStatus) {
lifeStatus = tempLifeStatus;
void drawfish() {
lifeDuration--;
if ((lifeDuration >= 0) && (lifeStatus == true))
image(jf, xLoc, yLoc, fishSize, fishSize);
else {
lifeStatus = true;
Thank you so much for helping if anyone can I would really appreciate it.
