The eeprom on the atmega328 is good for 100,000 writes before it burns out.
A SD card is good for 1,000,000 writes before burnout.
At 1440 writes per day, once a min, I will burn out a SD card in 70 days (Ignoring a rolling files system or other types of wear leveling). The data does not need to be static (live through a reboot).
Humm, is there a cmos/sram/dram chip out there around 512kb~1024kb that is simple to interface into the atmega328?
The specs are typically so many writes for a given location (probably a significant sized block on most modern flash cards.) So if you write 16 bytes at a time, once a minute, you would end up writing each block (say) 8 to 64 times before you went on to the next block. If you start with a 2G card, it looks like you would only have about 200 years worth of space before you'd have to wrap around to that first block again...
(assuming that the card doesn't do something "intelligent" internally, causing it to do something stupid.)
I was looking at the monster flash approach. It just seem a big waist to have a 2GB SD to hold about 1MB of data for 6~18 hours.
1440 samples a day
64 bytes a sample
128 devices (Arduino's all reporting to one)
((1440*64*128)/1024)/1024 = 11.25MB a day
2048/11.25=182 days to fill a 2GB SD
(182.04*1000000)/365=498,752 years to write each block 1,000,000 times. Wow, I will not care when I am 498,752 years old ;-)
My whole rig is solar and uses a GSM (cell) modem to up load data. I dont have enough power, at night, to transmit data all night long.
I think the 1 million writes is only for a significant percentage of the blocks. Many will last much longer. With the hardware wear levelling wouldn't you just need to increase the capacity to the point where you'll still have sufficient storage for a nights worth of data at the end of the project?
