How do I get privileges??? I need example code!!!
I have bought the genuine arduino Mega2560 and Ethernet boards to connect to Xively (pachube).
When clicking the link ‘PachubeClientString?’ to get example code and I get the message “Insufficient privileges to perform action.”
I have registered and logged. No different.
The example used to be accessible. What do I do to get the privileges. I can not find any references to this. Why is this not explained when the message appears so I know how to proceed. I am effectively locked out of getting the example code I need without knowing what to do about it.
Please help.
Perhaps you should show a link to the website if you expect one of us here to try it out.
There's a lesson here.
A vast majority of the Internet is utter rubbish. Not to speak of the fact that about a third of the traffic must be pornography, but (some) people make a living "creating" websites with all sorts of magic "features" - things that pop up, animations, "interactive" widgets and such. And on average they do a bad job of it, many of the features becoming unreliable, not properly tested with the various web browsers available, and such.
So when you come across a website that simply does not work and gives you such peculiar messages as you say - and let me be clear - the website has failed, so there is almost certainly nothing you can do - well, just accept it as "progress". :astonished:
If you can find a link for a "webmaster" to take responsibility, by all means send a complaint. Lots of luck!
{The fact that you had to "register" and "log in" is a very bad indication for a start.}
Thanks for your reply Paul.
I agree totally but perhaps I should have made it clearer... I am referring to this Arduino Site.
The example code I am trying to get access to is right down the bottom of this page
http://arduino.cc/en/Tutorial/ChatServer
the link PachubeClientString?
Thanks for your input.
I don't know what's up with those links - just forget them; instead, use google - if you google "PachubeClientString" - you'll get a github link to what is likely the working code:
https://github.com/PaulStoffregen/Ethernet/tree/master/examples
Actually - you'll get plenty of github links; likely the author had a github or google code account with the code on it at some point (maybe you can find it - if you can find who the original author is/was) - and it's been forked a little bit - but it should be enough to get started with.
Thanks for your suggestions cr0sh, I will check out github.
I have found some examples elsewhere but I would still like access to the 'official' examples and I would like to know why the arduino guys have restricted access and how do I get access???
The examples do not yet exist…
http://arduino.cc/en/Tutorial/PachubeClient
http://arduino.cc/en/Tutorial/PachubeClientString
I would like to know why the arduino guys have restricted access?
Because the links are to edit the page…
http://arduino.cc/en/Tutorial/PachubeClient?action=edit
…and how do I get access???
Get the Arduino folks to hire you.
Thank you Moderator CB. I wish they had put that with the restricted message when it came up. It would have saved a lot of time.
My comment about previously getting access related to the GSM Pachube example which I have previously used and I assumed this was the same.
