I don't understand why Serial.print(dVal) compiles but serialHC05.write(dVal) won't compile.
They're both HardwareSerial objects aren't they? (Serial and Serial2)
sketch\Debug.cpp: In member function 'void CDebug::dump(char, double)':
Debug.cpp:159: error: call of overloaded 'write(const double&)' is ambiguous
serialHC05.write(dVal);
sketch\Debug.cpp:159:26: note: candidates are:
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:232:0,
from sketch\Debug.cpp:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:129:20: note: virtual size_t HardwareSerial::write(uint8_t)
virtual size_t write(uint8_t);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:130:19: note: size_t HardwareSerial::write(long unsigned int)
inline size_t write(unsigned long n) { return write((uint8_t)n); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:131:19: note: size_t HardwareSerial::write(long int)
inline size_t write(long n) { return write((uint8_t)n); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:132:19: note: size_t HardwareSerial::write(unsigned int)
inline size_t write(unsigned int n) { return write((uint8_t)n); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:133:19: note: size_t HardwareSerial::write(int)
inline size_t write(int n) { return write((uint8_t)n); }
#define serialHC05 Serial2
void CDebug::log(const double dVal, const bool bNewLine)
#ifdef DEBUG
Serial.print(dVal);
if (bNewLine)
#elif defined DIAGNOSTIC
if (bNewLine)
serialHC05.write("\r\n");
#else
m_file.write(dVal);
if (bNewLine)
m_file.writeLine(F(""));
#endif
