#include "Arduino.h"
#if !defined(SERIAL_PORT_MONITOR)
#error "Arduino version not supported. Please update your IDE to the latest version."
#endif
#if defined(SERIAL_PORT_USBVIRTUAL)
// Shield Jumper on HW (for Leonardo and Due)
#define port SERIAL_PORT_HARDWARE
#define pcSerial SERIAL_PORT_USBVIRTUAL
#else
// Shield Jumper on SW (using pins 12/13 or 8/9 as RX/TX)
#include "SoftwareSerial.h"
SoftwareSerial port(12, 13);
#define pcSerial SERIAL_PORT_MONITOR
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
//Groups and Commands
enum Groups
GROUP_0 = 0,
GROUP_1 = 1,
enum Group0
G0_SERI = 0,
enum Group1
G1_LEDON = 1,
G1_LEDOFF = 0,
int8_t group, idx;
unsigned long time;
// setup PC serial port
pcSerial.begin(9600);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
time = millis();
// bridge mode?
int mode = easyvr.bridgeRequested(pcSerial);
switch (mode)
case EasyVR::BRIDGE_NONE:
// setup EasyVR serial port
port.begin(9600);
// run normally
pcSerial.println(F("---"));
pcSerial.println(F("Bridge not started!"));
case EasyVR::BRIDGE_NORMAL:
// setup EasyVR serial port (low speed)
port.begin(9600);
// soft-connect the two serial ports (PC and EasyVR)
easyvr.bridgeLoop(pcSerial);
// resume normally if aborted
pcSerial.println(F("Bridge connection aborted!"));
case EasyVR::BRIDGE_BOOT:
// setup EasyVR serial port (high speed)
port.begin(115200);
while (!easyvr.detect())
Serial.println("EasyVR not detected!");
easyvr.setPinOutput(EasyVR::IO1, LOW);
Serial.println("EasyVR detected!");
easyvr.setTimeout(5);
//�L : easyvr.setLanguage(%1!d!);
group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
unsigned long time2 = millis();
if(time2 - time >= 8000)
// I want to go the case G1_LEDOFF:
easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
Serial.print("Say a command in Group ");
Serial.println(group);
easyvr.recognizeCommand(group);
do
// can do some processing while waiting for a spoken command
while (!easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
idx = easyvr.getWord();
if (idx >= 0)
// built-in trigger (ROBOT)
// group = GROUP_X; <-- jump to another group X
return;
idx = easyvr.getCommand();
if (idx >= 0)
// print debug message
uint8_t train = 0;
char name[32];
Serial.print("Command: ");
Serial.print(idx);
if (easyvr.dumpCommand(group, idx, name, train))
Serial.print(" = ");
Serial.println(name);
easyvr.playSound(0, EasyVR::VOL_FULL);
// perform some action
action();
else // errors or timeout
if (easyvr.isTimeout())
Serial.println("Timed out, try again...");
int16_t err = easyvr.getError();
if (err >= 0)
Serial.print("Error ");
Serial.println(err, HEX);
void action()
digitalWrite(9,LOW);
switch (group)
case GROUP_0:
switch (idx)
case G0_SERI:
// if whisper , slowly Led On
for(int i = 0; i<16; i++)
analogWrite(9,i);
delay(20);
// write your action code here
static unsigned time = millis();
group = GROUP_1; //&lt;-- or jump to another group X for composite commands
case GROUP_1:
switch (idx)
case G1_LEDON:
group = GROUP_0;
digitalWrite(8, HIGH); // set the LED on
group = GROUP_1;
for(int i = 0; i<256; i++)
analogWrite(9,i);
delay(20);
case G1_LEDOFF:
group = GROUP_0; //&lt;-- or jump to another group X for composite commands
digitalWrite(8, LOW); // set the LED off
for(int i=255; i>=0; i--)
analogWrite(9,i);
delay(20);
hello sir
in Line 109, I used if sentence
if that sentence is satisfied
I want to implement line 218 ( case G1_LEDOFF )
How do I do ?
I used "goto"
but i think that's not solution
