I need to graph the pressure values in real time to detect pressure variations. ( Ive done all the necessary calculations to convert the voltage signal into a pressure value). Im currently using an arduino UNO.
Thanks for the help.
Where, on the UNO, do you plan to draw this graph?
The differential sensor has 3 pins connected to supply ground and an analog pin A0. I wish to plot a pressure vs time graph in real time using the sensor values. I would eventually have these values displayed on a touch screen. How do I do so?
touch screen
differential sensor
One step at a time. Learn to use the sensor, and print data on the serial monitor.
Then, learn how to connect the touch screen, and print data and/or plot on it.
Finally, put the two projects together. You will need a buffer to store some number of sensor readings, and plot those on the screen.
Some years ago I posted a project similar to yours on the AVRFreaks forum. Nine years later it is still working well!
The library for the display should have graph examples. It is essentially just a matter of converting time and data to pixels in order to locate a point. It might be wise select a display with a size that is convenient for what you intend to do.
Megunolink
This Forum Thread may be of interest
...R
