How do I invert a PH sensors output
I have had som troble with my PH sensor. My ref. is 7 and it is equal to 2,5V.
When my PH selotion is at 5 its writing 9 and the voltage is increased to 3V
The voltage is fine put I need the PH value to fall to 5
is it possible to invert the outcom from the sensor?
Sorry for my english :smiley:
Here is my code:
//PH:
unsigned long int PH_avgValue; //Gem den gennemsnitlige værdi fra sensor feedback
int buffer_array[10], temp;
//PH:
for (int i = 0; i < 10; i++) //PH: 10 prøver for at få en mere præcis værdi
buffer_array[i] = analogRead(A0);
delay(10);
for (int i = 0; i < 9; i++) //PH Sortere analog fra lille til stor
PH_avgValue = 0;
for (int i = 2; i < 8; i++) //Gennemsnitlig værdi fra 6 center prøver
PH_avgValue += buffer_array[i];
float phValue = (float)PH_avgValue * 4.15 / 1024 / 6; //Konventere analog til Volt og finde summen af de 6 center prøver
phValue = 3.5 * phValue; //Konventere Volt til PH værdi
if (phValue < 6)
Serial.print("PH for lav: ");
Serial.println(phValue);
delay(800);
else if (phValue > 8)
Serial.print("PH for høj: ");
delay(800);
Serial.print("PH OK :");
delay(800);
How about subtracting the result you get from fourteen?
It works! Thank you! I dont know why i diddint tink of that. so nice and simple
In another few years, you’ll probably be able to get a software patent on that method.
a7
:laughing: :laughing: :laughing:
