I have a very basic sketch I am wanting an LED to go through a startup sequence then remain lit after the sequence is finished I cannot for the life of me figure out how to achieve this. Obviously I am very new with this trying to put things together here. This is a headlight halo on my motorcycle I want the LED to light up red with the key on engine off, when the engine is started I want the led to go through a flicker sequence then light up white. I can handle getting it to do all this its just the staying lit up white part, the sketch below does not have any perameters yet for the inputs to tell the arduino when the key is on, or the engine is on (I am planning on crossing that bridge when I get there) so here is the sketch I have, also any thoughts you may have to clean this code up would be great!
int bluePin = 11;
int greenPin = 10;
int redPin = 12;
int bluerPin = 5;
int greenrPin = 6;
int redrPin = 3;
// initialize the digital pin as an output.
// Pin 13 has an LED connected on most Arduino boards:
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(3, OUTPUT);
pinMode(12, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
// startup sequence
//red key on no engine start
digitalWrite(greenrPin, HIGH);
digitalWrite(redrPin, LOW);
digitalWrite(bluerPin, HIGH);
digitalWrite(redPin, LOW);
digitalWrite(greenPin, HIGH);
digitalWrite(bluePin, HIGH);
delay(5000);
digitalWrite(redrPin, HIGH);
digitalWrite(redPin, HIGH);
delay(150);
//engine started
digitalWrite(bluerPin, LOW);
digitalWrite(bluePin, LOW);
delay(5);
delay(10);
delay(150);
delay(10);
delay(400);
delay(75);
delay(150);
delay(10);
delay(150);
//start white
digitalWrite(greenrPin, LOW);
digitalWrite(greenPin, LOW);
delay(10);
delay(150);
delay(150);
delay(250);
delay(150);
delay(10);
delay(150);
delay(10000);
delay(150);
}[code]
[/code]
