I am trying to display the time from a RTC on a ST7796S display and change text color from a web server, I copied code from the AP_SimpleWebServer example and the time only updates when a button is pushed on the web server her is my code.
#include <WiFiS3.h>
#include <Wire.h>
#include "Arduino.h"
#include "uRTCLib.h"
#include <Adafruit_GFX.h>
#include <Adafruit_ST7796S_kbv.h>
#include <SPI.h>
#include "arduino_secrets.h"
#define TFT_CS 10
#define TFT_DC 9
#define TFT_RST 8
Adafruit_ST7796S_kbv tft = Adafruit_ST7796S_kbv(TFT_CS, TFT_DC, TFT_RST);
uRTCLib rtc(0x68);
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key index number (needed only for WEP)
int led = LED_BUILTIN;
int status = WL_IDLE_STATUS;
WiFiServer server(80);
int rtchour;
int day;
int hour;
int minute;
int second;
int lday;
int lhour;
int lminute;
int lsecond;
int inDisTime = 1;
int Pm = 0;
int lPm = 0;
int timeColor = 2;
delay(3000); // wait for console opening
URTCLIB_WIRE.begin();
// Comment out below line once you set the date & time.
// Following line sets the RTC with an explicit date & time
rtc.set(45 ,59, 23, 2, 11, 2, 25);
// rtc.set(second, minute, hour, dayOfWeek, dayOfMonth, month, year)
// set day of week (1=Sunday, 7=Saturday)
tft.begin();
tft.setRotation(1);
tft.fillScreen(ST7796S_BLACK);
//wifi setup
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Access Point Web Server");
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// by default the local IP address will be 192.168.4.1
// you can override it with the following:
WiFi.config(IPAddress(192,48,56,2));
// print the network name (SSID);
Serial.print("Creating access point named: ");
Serial.println(ssid);
// Create open network. Change this line if you want to create an WEP network:
status = WiFi.beginAP(ssid, pass);
if (status != WL_AP_LISTENING) {
Serial.println("Creating access point failed");
// don't continue
while (true);
// wait 10 seconds for connection:
delay(10000);
// start the web server on port 80
server.begin();
// you're connected now, so print out the status
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
// Capture last known values
lday = rtc.day();
if((rtchour > 0) && (rtchour < 13)){hour = rtchour;}
if(rtchour > 12){lhour = rtchour - 12; lPm = 1;}
if(rtchour == 0){lhour = 12; lPm = 0;}
lminute = rtc.minute();
lsecond = rtc.second();
// Refresh RTC and get new values
rtc.refresh();
rtchour = rtc.hour();
day = rtc.day();
if(rtchour > 12){hour = rtchour - 12; Pm = 1;}
if(rtchour == 0){hour = 12; Pm = 0;}
Serial.print("Last Second: ");
Serial.println(lsecond);
Serial.print("Current Second: ");
Serial.println(second);
if ((lsecond != second) || (inDisTime == 1)) {
tft.setTextColor(ST7796S_BLACK);
tft.setTextSize(8);
if(lhour > 9){tft.setCursor(40, 140); tft.print(lhour);}
else{tft.setCursor(100, 140); tft.print(lhour);}
tft.print(":");
if(lminute < 10){tft.print("0"); tft.print(lminute);}
else{tft.print(lminute);}
tft.print(":");
tft.print(lsecond);
tft.setTextSize(3);
if((lPm == 1) || (rtchour == 12)){tft.print("PM");}
if((lPm == 0) && (rtchour != 12)){tft.print("AM");}
if(timeColor == 1){tft.setTextColor(ST7796S_GREEN);}
if(timeColor == 2){tft.setTextColor(ST7796S_BLUE);}
tft.setTextSize(8);
if(hour > 9){tft.setCursor(40, 140); tft.print(hour);}
else{tft.setCursor(100, 140); tft.print(hour);}
tft.print(":");
if(minute < 10){tft.print("0"); tft.print(minute);}
else{tft.print(minute);}
tft.print(":");
tft.print(second);
tft.setTextSize(3);
if((Pm == 1) || (rtchour == 12)){tft.print("PM");}
if((Pm == 0) && (rtchour != 12)){tft.print("AM");}
inDisTime = 0;
tft.setTextSize(3);
tft.setCursor(10, 210);
tft.print(daysOfTheWeek[rtc.dayOfWeek()]);
tft.print(", ");
if(rtc.month() == 1){tft.print("January ");}
if(rtc.month() == 2){tft.print("February ");}
if(rtc.month() == 3){tft.print("March ");}
if(rtc.month() == 4){tft.print("April ");}
if(rtc.month() == 5){tft.print("May ");}
if(rtc.month() == 6){tft.print("June ");}
if(rtc.month() == 7){tft.print("July ");}
if(rtc.month() == 8){tft.print("August ");}
if(rtc.month() == 9){tft.print("Septeber ");}
if(rtc.month() == 10){tft.print("October ");}
if(rtc.month() == 11){tft.print("November ");}
if(rtc.month() == 12){tft.print("December ");}
tft.print(rtc.day());
tft.print(", ");
tft.print(rtc.year());
if(hour != lhour){tft.fillScreen(ST7796S_BLACK); lhour = hour;}
Serial.print("Hour: ");
Serial.println(hour);
Serial.print("Minute: ");
Serial.println(minute);
Serial.print("Second: ");
if (status != WiFi.status()) {
// it has changed update the variable
status = WiFi.status();
if (status == WL_AP_CONNECTED) {
// a device has connected to the AP
Serial.println("Device connected to AP");
// a device has disconnected from the AP, and we are back in listening mode
Serial.println("Device disconnected from AP");
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
delayMicroseconds(10); // This is required for the Arduino Nano RP2040 Connect - otherwise it will loop so fast that SPI will never be served.
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out to the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("<p style=\"font-size:7vw;\">Click <a href=\"/timeGreen\">here</a> to make time GREEN<br></p>");
client.print("<p style=\"font-size:7vw;\">Click <a href=\"/timeBlue\"</a> to make time Blue<br></p>");
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
continue;
else { // if you got a newline, then clear currentLine:
currentLine = "";
else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Check to see if the client request was "GET /H" or "GET /L":
if (currentLine.endsWith("GET /timeGreen")) {
timeColor = 1; // GET /H turns the LED on
if (currentLine.endsWith("GET /timeBlue")) {
timeColor = 2; // GET /L turns the LED off
// close the connection:
client.stop();
Serial.println("client disconnected");
