How do I know my Bluno is connected (Arduino UNO + Bluetooth 4.0)
Hi Guys I have a Bluno which is an Arduino Uno compatible board with built in Blootooth 4.0
I am trying to create a protocol to control it from an Android smartphone.
I would like to know how to detect that it is connected.
Serial.available() simply returns true if there is something in the buffer Serial.begin(115200) returns nothing other than setting up the board so a repeat Serial.begin(115200) while connected will not help.
Any pointers would be appreciated
Connected on which end? Or, did you mean paired?
You implied that the bluetooth device was physically connected to the Arduino, so the status of that end should not bi in question.
There is no way to know that the other end is connected, unless the device on the other end of the connection is chatty kathy.
I connect to the bluno with an android phone over blue tooth. When I connect, a little led turns on, on the board and I can now send and receive bytes over Bluetooth. I'd like to know from within the bluno program that I am now connected with a device.
For example, While connected, I can't send a new sketch to the bluno because the com port is engadged with the android device. If I disconnect from the android device, the led on the bluno board switches off and the serial port becomes available.
So, put a photodetector above the LED, so you can sense when it is on or off. :)
Or look at the schematics to see how the LED is wired, and perhaps tap into the circuit.
Hmm ... Great idea ! I will try
