hello im new to arduino, sometimes this reach 105% which makes my esp32 not working... how can i lessen this more..
Sketch uses 1248836 bytes (95%) of program storage space. Maximum is 1310720 bytes.
Global variables use 50292 bytes (15%) of dynamic memory, leaving 277388 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.8.1
Serial port COM7
Connecting....
Chip is ESP32-D0WD-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: a0:dd:6c:02:bd:74
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
#define GREEN_LED_PIN 26 // Change to GPIO 26
#define RED_LED_PIN 27 // Change to GPIO 27
#define DHTPIN 4 // new added - GPIO4 (can be any digital pin)
#define DHTTYPE DHT22 //new added - DHT 22 (AM2302)
#include <ArduinoJson.h>
#include <Arduino.h>
#include <WiFi.h>
#include <time.h>
#include <Firebase_ESP_Client.h>
//Provide the token generation process info.
#include "addons/TokenHelper.h"
//Provide the RTDB payload printing info and other helper functions.
#include "addons/RTDBHelper.h"
#include <DHT.h>
const char* wifiList[][3] PROGMEM = {
{"HUAWEI-D8kG", "ana@36546"},
{"TECNNO CAMON 20 Pro", "vidallo12345"},
{"Carlo", "carlfrancis0205"},
{"Kaida", "Kaida123"},
{"Hotspot", "12468642369485"},
{"VILLA", "arielvillajr."},
{"CCT2-512", "ccthospes2019"},
{"HG8145V5_D400A", "jcww2myE"},
const int numNetworks = sizeof(wifiList) / sizeof(wifiList[0]);
//Define Firebase Data object
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
FB_Firestore firestore;
unsigned long sendDataPrevMillis = 0;
int count = 0;
bool signupOK = false;
const int sensorPin1 = 34;
const int sensorPin2 = 35;
const int sensorPin3 = 33;
const int sensorPin4 = 32;
// Calibration values based on your tests
const int dryValue1 = 2480, wetValue1 = 580;
const int dryValue2 = 2475, wetValue2 = 600;
const int dryValue3 = 2480, wetValue3 = 660;
const int dryValue4 = 2430, wetValue4 = 500;
// Initialize the DHT sensor
DHT dht(DHTPIN, DHTTYPE);
void connectToWiFi() {
WiFi.mode(WIFI_STA);
for (int i = 0; i < numNetworks; i++) {
Serial.print("Trying to connect to: ");
Serial.println(wifiList[i][0]);
WiFi.begin(wifiList[i][0], wifiList[i][1]);
int attempts = 20; // Timeout after ~10 seconds
while (WiFi.status() != WL_CONNECTED && attempts > 0) {
Serial.print(".");
attempts--;
if (WiFi.status() == WL_CONNECTED) {
Serial.println("\n✅ Connected to WiFi!");
Serial.print("IP Address: ");
digitalWrite(RED_LED_PIN, LOW);
digitalWrite(GREEN_LED_PIN, HIGH);
return;
Serial.print("\n❌ Failed to connect to ");
Serial.print("Error Code: ");
Serial.println(WiFi.status());
Serial.println("⚠️ Could not connect to any WiFi. Retrying in 10 seconds...");
delay(10000);
ESP.restart(); // Restart only if all networks fail
float averageMoisture(int readings[], int count) {
float sum = 0;
for (int i = 0; i < count; i++) {
sum += readings[i];
return sum / count; // Return the average
void readAndDisplaySensorValues() {
//Serial.println(WiFi.localIP());
// Read soil moisture sensor values
int moisture1 = analogRead(sensorPin1);
int moisture2 = analogRead(sensorPin2);
int moisture3 = analogRead(sensorPin3);
int moisture4 = analogRead(sensorPin4);
int moisturePercent1 = map(moisture1, dryValue1, wetValue1, 0, 100);
int moisturePercent2 = map(moisture2, dryValue2, wetValue2, 0, 100);
int moisturePercent3 = map(moisture3, dryValue3, wetValue3, 0, 100);
int moisturePercent4 = map(moisture4, dryValue4, wetValue4, 0, 100);
// Ensure values stay between 0% and 100%
moisturePercent1 = constrain(moisturePercent1, 0, 100);
moisturePercent2 = constrain(moisturePercent2, 0, 100);
moisturePercent3 = constrain(moisturePercent3, 0, 100);
moisturePercent4 = constrain(moisturePercent4, 0, 100);
float temperature = dht.readTemperature(); // Read temperature
float humidity = dht.readHumidity(); // Read humidity
// Calculate average moisture
int moistureReadings[] = {
moisturePercent1,
moisturePercent2,
moisturePercent3,
moisturePercent4};
float averageMoistureLevel = averageMoisture(moistureReadings, 4);
// // Display the values on the Serial Monitor
if (Firebase.RTDB.setInt(&fbdo, "Moisture/MoistureReadings_1", moisturePercent1)){
else {
Serial.println("FAILED");
Serial.println("REASON: " + fbdo.errorReason());
if (Firebase.RTDB.setInt(&fbdo, "Moisture/MoistureReadings_2", moisturePercent2)){
else {
if (Firebase.RTDB.setInt(&fbdo, "Moisture/MoistureReadings_3", moisturePercent3)){
else {
if (Firebase.RTDB.setInt(&fbdo, "Moisture/MoistureReadings_4", moisturePercent4)){
else {
if (Firebase.RTDB.setFloat(&fbdo, "Moisture/Average", averageMoistureLevel)){
else {
if (Firebase.RTDB.setFloat(&fbdo, "Temperature/temperature", temperature)){
else {
if (Firebase.RTDB.setFloat(&fbdo, "Humidity/humidity", humidity)){
else {
Serial.println("Soil Moisture Levels:");
Serial.print("Sensor 1: "); Serial.print(moisturePercent1); Serial.println("%");
Serial.print("Sensor 2: "); Serial.print(moisturePercent2); Serial.println("%");
Serial.print("Sensor 3: "); Serial.print(moisturePercent3); Serial.println("%");
Serial.print("Sensor 4: "); Serial.print(moisturePercent4); Serial.println("%");
Serial.print("Average Soil Moisture: "); Serial.print(averageMoistureLevel); Serial.println("%");
Serial.print("Temperature: "); Serial.print(temperature); Serial.println("°C");
Serial.print("Humidity: "); Serial.print(humidity); Serial.println("%");
} //new added
// Firestore starts here!!!!!!!
// This for setting the time no need na sa RTC component instead we using network time protocol
void setupTime() {
if (WiFi.status() != WL_CONNECTED) {
Serial.println("WiFi not connected! Cannot sync time.");
return;
const long gmtOffset_sec = 8 * 3600; // GMT+8 (Philippines, Singapore, etc.)
const int daylightOffset_sec = 0; // No DST in many countries
configTime(gmtOffset_sec, daylightOffset_sec, "pool.ntp.org");
configTime(8 * 3600, 0, "pool.ntp.org", "time.google.com", "asia.pool.ntp.org");
Serial.println("Syncing time...");
delay(5000); // Wait for NTP sync
time_t now = time(nullptr);
int attempts = 10;
while (now < 1000000000 && attempts > 0) { // Check if time is reasonable
Serial.println("Waiting for NTP sync...");
attempts--;
if (now < 1000000000) {
Serial.println("❌ Failed to get time from NTP!");
Serial.println("✅ Time synchronized!");
//Getting the Date and Time here
String getDateString() {
struct tm timeInfo;
localtime_r(&now, &timeInfo);
char buffer[11]; // YYYY-MM-DD format
strftime(buffer, sizeof(buffer), "%Y-%m-%d", &timeInfo);
return String(buffer);
String getTimeString() {
struct tm timeInfo;
char buffer[9]; // HH-MM-SS format
strftime(buffer, sizeof(buffer), "%H-%M-%S", &timeInfo);
String getSelectedPlot() {
String selectedPlot;
if (Firebase.RTDB.getString(&fbdo, "SelectedPlot/plotName")) {
selectedPlot = fbdo.stringData();
Serial.println("Selected Plot: " + selectedPlot);
Serial.println("Failed to get selected plot: " + fbdo.errorReason());
selectedPlot = "Plot1"; // Default to Plot1 if failed
return selectedPlot;
// Connecting and creating logs storing to Firestore
void saveDailyLogToFirestore(float temperature, float humidity, float avgMoisture,
int moisture1, int moisture2,
int moisture3,
int moisture4) {
FirebaseJson json;
// Get current date and time
String dateString = getDateString();
String timeString = getTimeString();
// Get time in ISO 8601 format
struct tm timeInfo;
gmtime_r(&now, &timeInfo); // Convert to UTC time
char isoTime[25]; // "YYYY-MM-DDTHH:MM:SSZ"
strftime(isoTime, sizeof(isoTime), "%Y-%m-%dT%H:%M:%SZ", &timeInfo);
//print debugg statemnt
Serial.print("Current timestamp: ");
Serial.println(isoTime);
// Get selected plot
String selectedPlot = getSelectedPlot();
json.set("fields/plot/stringValue", selectedPlot);
json.set("fields/timestamp/timestampValue", isoTime);
json.set("fields/temperature/doubleValue", temperature);
json.set("fields/humidity/doubleValue", humidity);
json.set("fields/average_moisture/doubleValue", avgMoisture);
json.set("fields/moisture_1/integerValue", moisture1);
json.set("fields/moisture_2/integerValue", moisture2);
json.set("fields/moisture_3/integerValue", moisture3);
json.set("fields/moisture_4/integerValue", moisture4);
String jsonString;
json.toString(jsonString, true);
// Firestore path: "Plots/{selectedPlot}/sensorData/{dateString}/{timeString}"
String collectionPath = "Plots/" + selectedPlot + "/sensorData";
String documentPath = dateString + "_" + timeString; // Ensures valid document ID
// Creating document and collection logs to the firestore
if (firestore.createDocument(&fbdo, "test-monitor-reui", "", collectionPath.c_str(), documentPath.c_str(), jsonString.c_str(), "")) {
Serial.println("Daily log saved: " + collectionPath + "/" + documentPath);
Serial.println("Failed to save log: " + fbdo.errorReason());
void listenForPlotChanges() {
Firebase.RTDB.getString(&fbdo, "SelectedPlot");
String selectedPlot = fbdo.stringData();
Serial.print("Selected Plot: ");
Serial.println(selectedPlot);
if (selectedPlot == "Plot 1") {
// Read sensors for Plot 1
readAndDisplaySensorValues();
} else if (selectedPlot == "Plot 2") {
// Read sensors for Plot 2
void setup(){
pinMode(GREEN_LED_PIN, OUTPUT);
pinMode(RED_LED_PIN, OUTPUT);
digitalWrite(RED_LED_PIN, HIGH); // Assume system is not ready
digitalWrite(GREEN_LED_PIN, LOW); // Turn off green LED initially
connectToWiFi();
setupTime(); // Initialize time
/* Assign the api key (required) */
config.api_key = API_KEY;
/* Assign the RTDB URL (required) */
config.database_url = DATABASE_URL;
dht.begin(); //begin dht sens
/* Sign up */
if (Firebase.signUp(&config, &auth, "", "")){
Serial.println("ok");
signupOK = true;
else{
Serial.printf("%s\n", config.signer.signupError.message.c_str());
/* Assign the callback function for the long running token generation task */
config.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
Firebase.begin(&config, &auth);
Firebase.reconnectWiFi(true);
listenForPlotChanges(); // Check Firebase for the selected plot
// Storing For Realtime
if (Firebase.ready() && signupOK && (millis() - sendDataPrevMillis > 2000 || sendDataPrevMillis == 0)) {
sendDataPrevMillis = millis();
// Get current time for
struct tm timeInfo;
int currentHour = timeInfo.tm_hour;
int currentMinute = timeInfo.tm_min;
static int lastLoggedMinute = -1;
static int lastLoggedHour = -1;
// **Scheduled logging at specific hours**
if ((currentHour == 8 || currentHour == 11 || currentHour == 12 ||currentHour == 13 ||
currentHour == 14 ||currentHour == 15 || currentHour == 17 || currentHour == 3 || currentHour == 4 ) &&
lastLoggedHour != currentHour) {
lastLoggedHour = currentHour;
logSensorDataToFirestore();
Serial.println("📌 Firestore log saved (Scheduled Time).");
// Function to log sensor data to Firestore
// Just calling this function inside the loop function
void logSensorDataToFirestore() {
float avgMoisture = (moisturePercent1 + moisturePercent2 + moisturePercent3 + moisturePercent4) / 4.0;
saveDailyLogToFirestore(temperature, humidity, avgMoisture,
moisturePercent1, moisturePercent2,
moisturePercent3, moisturePercent4, getSelectedPlot());
