I tested it with two different sensors
unfortunately even when I dry the sensor from wet,
it still same value I also Is using a resistor as well hmm.
I made following that seems to work
const byte sensor0 = A0;
const byte sensor1 = A1;
int rawValue0;
int rawValue1;
#define soilWet 500 // Define max value we consider soil 'wet'
#define soilDry 750 // Define min value we consider soil 'dry'
#define sensorPower 7
rawValue0 = analogRead(sensor0); // dummy read
delay(1); // settle
rawValue0 = analogRead(sensor0); // keep
rawValue1 = analogRead(sensor1);
delay(1);
int moisture0 = readSensor0();
int moisture1 = readSensor1();
Serial.println("--------------------------------------");
Serial.print("Moisture 0 raw: ");
Serial.println(rawValue0);
// Determine status of our soil
if (moisture0 < soilWet) {
Serial.println("Status: Soil is too wet");
} else if (moisture0 >= soilWet && moisture0 < soilDry) {
Serial.println("Status: Soil moisture is perfect");
Serial.println("Status: Soil is too dry - time to water!");
delay(4000);
Serial.print("Moisture 1 raw: ");
Serial.println(rawValue1);
if (moisture1 < soilWet) {
} else if (moisture1 >= soilWet && moisture1 < soilDry) {
int readSensor0() {
digitalWrite(sensorPower, HIGH); // Turn the sensor ON
delay(10); // Allow power to settle
int val = analogRead(sensor0); // Read the analog value form sensor
digitalWrite(sensorPower, LOW); // Turn the sensor OFF
return val; // Return analog moisture value
int readSensor1() {
int val = analogRead(sensor1); // Read the analog value form sensor
How could I simplifiy this ? so bad coded.
Don´t make code duplicates.
Create an object that contains all the necessary information, such as port pin, wet value, dry value, timing information, etc. A structured array represents the list of measuring points and a corresponding service takes care of this data.
You are indicating that the sensor produces the same reading when held in the air as when held in the water?
Post an image of your project.
#define pin0 A0
#define pin1 A1
#define pin2 A2
#define pin3 A3
#define pin4 A4
#define pin5 A5
#define pin6 A6
#define pin7 A7
byte Pins[] = {pin0, pin1, pin2,pin3,pin4,pin5,pin6,pin7};
void setup(){
void loop(){
for (int x = 0; x < 7; x++){
Serial.println(analogRead(Pins[x]));
Serial.print("pin: ");
Serial.println(Pins[x]);
How can I add into the loop what pin is printed?
Print as hex values...
this is what I got so far but it seems like analogPin 1 is printing wrong value:
#define pin0 A0
#define pin1 A1
#define pin2 A2
#define pin3 A3
#define pin4 A4
#define pin5 A5
#define pin6 A6
#define pin7 A7
struct {
int pin;
int value;
int percentage;
int Dry;
int Wet;
} sensor[19]; //20
int analogPin1 = A0;
int analogPin2 = A1;
int analogPin3 = A2;
int analogPin4 = A3;
int analogPin5 = A4;
int analogPin6 = A5;
int analogPin7 = A6;
int analogPin8 = A7;
Serial.begin(9600); // open the serial port at 9600 bps:
sensor[0].pin = A0;
sensor[1].pin = A1;
sensor[2].pin = A2;
sensor[3].pin = A3;
sensor[4].pin = A4;
sensor[5].pin = A5;
sensor[6].pin = A6;
sensor[7].pin = A7;
sensor[0].Dry = 750;
sensor[0].Wet = 500;
sensor[1].Dry = 750;
sensor[1].Wet = 500;
sensor[2].Dry = 750;
sensor[2].Wet = 500;
sensor[3].Dry = 750;
sensor[3].Wet = 500;
sensor[4].Dry = 750;
sensor[4].Wet = 500;
sensor[5].Dry = 750;
sensor[5].Wet = 500;
sensor[6].Dry = 750;
sensor[6].Wet = 500;
sensor[7].Dry = 750;
sensor[7].Wet = 500;
for (int i = 0; i < 2; i++) {
Serial.println("Moisture:");
Serial.println(i, DEC); // print as an ASCII-encoded decimal
delay(10);
Serial.println(analogRead(sensor[i].pin));
delay(4000);
Moisture:
1
981
Moisture:
0
1023
Moisture:
1
981
though AnalogPin0 is working fine.
Any ideas?
below is how I connected:
Thanks solved that part @build_1971 though other issues now.
See my last post @Idahowalker
Which ones...
We didn't see any links or pictures yet.
As the youtube video shows, more than 82% tested were crap.
My code should work if... you have the right sensors.
Leo..
Bad ground connection to sensor 0? Breadboard connections may easily get loose. Take care that your wires go in far enough. Wobble them to see if things improve...
Why would 981 be good?
Don't you expect all values to be within 500 -750 range?
Also, you might wanna use for loop to initialize your struct.
for (int i=0; i<7; i++){
sensor[i].Wet = 500;
sensor[i].Dry = 750;
what for sensor do you recommend any particular?
that have good quality.
indead hmm though with some code they display a range between 1023-400~ and with some other code 980-450~
I am not sure honetly what is proberly right unfortunately.
The sensor you already have...
Unfortunately several manfacturers are making them, and some are cutting corners.
That's why I asked you for a picture of the sensors you have.
Need to know which exact parts are used.
It's all explained in that youtube video.
Leo..
The first link is the sensor you should use.
It has the 3.3volt regulator and maybe the right 555, and maybe the 1Megohm resistor.
Need to see the exact printing on the 555 chip to confirm,
and you need to measure the resistance between output and ground (should be 1Megohm).
The second link...
Throw it all in the bin.
Leo..
Ok I get back to you!
many thanks!
I tested both 5 volt and 3.3 volt then I get very low values:
Moisture:
1
238
Moisture:
0
111
I bought some new Soil moisture v2 I hope those works better.
You should only use 5volt. The sensors (should) have their own 3,3volt regulator
So you didn't show us what the old sensors (printing on the chips).
and you ordered another unknown lot without asking first.
I'm out..
Leo..
