How do i make it so the program doesnt just spit out the else option every time
every time it gives me the Not right option
String forward = "f";
String back = "b";
String left = "l";
String right = "r";
    Serial.println("drive");
  while (Serial.available() == 0) {
  String input = Serial.readString();
  if(input == forwardj){
   //code
      Serial.println("forward");
   if(input == back){
   //code
  Serial.println("back");
    if(input == left){
   //code
  Serial.println("left");
    if(input == right){
      //code
   Serial.println("right");
      Serial.println("not right");
i am quite new so please don't overheat my braicells
Welcome to the forum
What have you got Line ending set to in the Serial monitor ?
Where the variables naprej and nazaj are defined?
oopsie i was translating and it seems i missed a few lines
fixed it
NL- the second option
Did you forget the forwardj variable ?
Set it to No Line ending
lol
Will the commands every be more than a single character?
About the forum rules: please do not edit the code in place. Every time you fixed errors in the code - insert it again as a new message.
A common way to prevent endless printing is to remember the last input that was received and compare it with new input. Only if they differ, do things; else simply do nothing.
oka sry i just got here
these are very basic one letter ones, but when i translate it back to my language or want a left-forward turn it would be nice to have a multiple letter option
How does this fix it?
When you use readString() what you have got set as the line ending is included in the String that it returns
If you change the mind to use one-letter command, the code can be less complicated.
nah.
i have been doing this for three days and haven't even started o the code.
i'm fine
What is this line doing? Compare it to some examples.
It is waiting for at least a single byte of Serial data to become available
