How do I make my "cases" stop after a short time?
Hello
Im building a small 4w4 car and I need some help with my code.
Im using IR remote and "case" to controll my car. My problem is that when I press "forward", "backward", "left" or "right" on my IR, the car never stops..
Is it possible to make the cases last for only a short time? So that if I press "left" the car will just turn left 45 degrees (for example)?
Or maybe someone could show me a finished "arduino IR car code"?
Thanks
Can't you just take your finger off the button?
Without seeing your code we are blind.
I wonder if you are using the delay() function?
...R
When I press a button on my remote, the car starts to drive. That's good for the "forward" and "backward" cases, but I want the car to only turn for a short time when I press "left" or "right".
I was told I should use "millis", not "delay" in my code..
My code is:
const int ldr = A7;   //Lyssensor (LDR), Light sensor
const int led = 3;    //Kjørelys, Lights
const int blaa1 = 4;
const int lys = 300;  //Laveste verdi for lys (styrer kjørelyset), Light value
const int mhp = 8;    //MotorHøyrePositiv
const int mhn = 9;    //MotorHøyreNegativ
const int mvp = 10;   //MotorVenstrePositiv
const int mvn = 11;   //MotorVenstreNegativ
#include <IRremote.h>  //Inkluderer biblioteket for IR kontroll
int RECV_PIN = 5;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
 pinMode(3, OUTPUT);  //Kjørelys
 pinMode(4, OUTPUT);  //Blått lys (indikerer at kjørelys er PÅ)
 irrecv.enableIRIn();
 pinMode(mhp, OUTPUT);
 digitalWrite(mhp, LOW);
 pinMode(mhn, OUTPUT);
 digitalWrite(mhn, LOW);
 pinMode(mvp, OUTPUT);
 digitalWrite(mvp, LOW);
 pinMode(mvn, OUTPUT);
 digitalWrite(mvn, LOW);
void loop(){
//LYS / LIGHTS - START
int lysverdi = analogRead(ldr);
  Serial.println(lysverdi);
  if (lysverdi < lys)
  digitalWrite(led, HIGH);
  digitalWrite(led, LOW);
  if (lysverdi < lys)
  digitalWrite(blaa1, HIGH);
  digitalWrite(blaa1, LOW);
  delay(200);
//LYS / LIGHTS - STLUTT
//IR, MOTOR - START
 if (irrecv.decode(&results)){
  Serial.println(results.value, DEC);
  irrecv.resume();
 delay(100);
 switch (results.value){
case 16712445:  //STOPP    >>|
case 16736925:  //Forward    CH
digitalWrite(mhn, HIGH);
digitalWrite(mvp, HIGH);
case 16754775:  //Backward    +
digitalWrite(mhp, HIGH);
digitalWrite(mvn, HIGH);
case 16720605:  //Left           |<<
case 16761405:  //Right         >||
case 16769565:  //Lights On    CH+
case 16753245:  //Lights Off    CH-
//IR, MOTOR - SLUTT
HansiFansi:
What happens if you take your finger off the button after a short time?
KenF:
I don't hold down the buttons on my IR remote.. I just press them for a short time, then let go.
When I press "forward" the car drives forward until I press a new button.. It will never stop unless I press "stop" on my remote.. (or the battery dies)
The easiest way to do it is to use delay in your right and left clauses. You'll also need to set results.value to zero after the delay or it will trigger more turns - the behavior you see now.
Both of those things are nasty hacks though, Better to use the blink without delay technique to do a shorter turn. You'll probably want to look up state machines too.
Ah just looked at your code. You seem to be using 4 independent motors to drive it. You don't have servos to steer it?
HansiFansi:
Is that what you want to happen?
If not, please describe what you would like to happen. You probably need to give a lot of detail so we know what code changes would be needed.
Can you confirm that, with the present code, it does stop when you press stop?
...R
Robin2:
...R
This is what I want the IR remote / car to do:
IR remote forward (short press) = Car drives forward (don't stop)
IR remote bacward (short press) = Car drives bacward (don't stop)
IR remote left (short press) = Car turns left (turns around, then stop) (the turning time will decide the angle the car turns)
IR remote right (short press) = Car turns right (turns around, then stop) (the turning time will decide the angle the car turns)
IR remote stop (short press) = Car stops
IR remote lights on/off (short press) = The lights on the car turns on/off (and stays on/off until I press off/on) IR remote overdrives the LDR (light sensor)
OK The problem is, that once it stops turning, it needs to go back to doing what it was doing before you started turning.
So I've altered your code, this takes note of wether you're going Forwards, Reversing or Stopped. in a separate variable.
When it recieves a signal to turn, it turn and wait for a tenth of a second, At this point if no other signal is being recieved, it should resume it's previous operation (forwards, reverse or stop).
You may have to alter some of the details but see how it goes.
int RECV_PIN = 5;
void setup(){
char currentDirection='S'; //S for stop, F forwards, R reverse
void loop(){
  if (lysverdi < lys)
  if (lysverdi < lys)
  delay(200);
//IR, MOTOR - START
  irrecv.resume();
 delay(100);
currentDirection='F';
currentDirection='R';
delay(100);
delay(100);
default://if no input continue in current mode
  switch(currentDirection)
     case 'S':  //STOPP
     case 'F':  //Forward
     case 'R':  //Backward
//IR, MOTOR - SLUTT
Thank you @KenF !
Will test the code later tonight :slight_smile:
KenF:
int RECV_PIN = 5;
void setup(){
void loop(){
  if (lysverdi < lys)
  if (lysverdi < lys)
  delay(200);
//IR, MOTOR - START
  irrecv.resume();
delay(100);
delay(100);
delay(100);
    case 'S':  //STOPP
    case 'F':  //Forward
//IR, MOTOR - SLUTT
Hi. The car still doesn't "stop" after turning :confused: I managed to make the car "turn and stop" once, but I haven't managed to recreate that scenario. I have tried every possible combinations on my remote (forward then left, backward then left, left then right, and so on.. )
Is it possible to make the car stop after turning and not go back to the previous case? Would that be easier?
Thanks for all you good help btw!
You could add a case for all off, and when you finish a turn, change the variable that drives the case to that. So if you had a case of 10, just set results.value = 10; as the last part of one of the turn statements.
