Hi everyone,
Here's my issue, I have a TFT shield that displays a number when my encoder count is within a certain range. The problem is that the draw time is slow so I do not want the number being redrawn every count the encoder is within its range. Heres an example of how this will function:
EncoderCount < 100 {display 'Position 1' }
EncoderCount >= 100 && EncoderCount < 200 {display 'Position 2' }
EncoderCount >= 200 && EncoderCount < 300 {display 'Position 3' }
EncoderCount >= 300 && EncoderCount < 400 {display 'Position 4' }
Theoretically I could make it so that as soon as the threshold is crossed, the position number can be drawn only once and the rest of the range will be exempt. The problem with that is encoders can sometimes skip counts and hence may miss the small window ( >=100 && < 101 )
So I'm wondering if there is a function that I'm missing that will allow me to draw the position number once while the encoder count is within a certain range, but not redraw anything until the count crosses another threshold.
My first solution was to create another variable count that will track the position, which works, but only in one direction. The encoder will be counting up and down at times. Below is my current code, using a simple counter to simulate the encoder.
Thanks in advance for your help.
*thought just now: Would OOP help me with this issue?
#include <stdint.h>
#include <TFTv2.h>
#include <SPI.h>
int drawnNumber = 0;
TFT_BL_ON; // turn on the background light
Tft.TFTinit(); // init TFT library
Tft.drawChar('1',80,40,20,WHITE);
for (int i = 1; i < 1000; i++) {
displayEnc(i);
drawBigNum(i);
// delay(1);
int drawBigNum(long encCounter) {
if (encCounter < 100 && drawnNumber == 0) {
drawOneWht();
drawnNumber = 1;
if (encCounter >= 100 && encCounter < 200 && drawnNumber == 1) {
drawOneRed();
drawnNumber = 2;
if (encCounter >= 200 && encCounter < 300 && drawnNumber == 2) {
drawTwoWht();
drawnNumber = 3;
if (encCounter >= 300 && encCounter < 400 && drawnNumber == 3) {
drawTwoRed();
drawnNumber = 4;
if (encCounter >= 400 && encCounter < 500 && drawnNumber == 4) {
drawThreeWht();
drawnNumber = 5;
if (encCounter >= 500 && encCounter < 600 && drawnNumber == 5) {
drawThreeRed();
drawnNumber = 6;
void displayEnc(long encCount) {
Tft.fillRectangle(8, 230, 150,45,BLACK);
Tft.drawNumber(encCount,10,240,4,WHITE);
void drawOneWht() {
Tft.fillRectangle(70, 30, 170,170,BLACK);
void drawOneRed() {
Tft.drawChar('1',80,40,20,RED);
void drawTwoWht() {
Tft.drawChar('2',80,40,20,WHITE);
void drawTwoRed() {
Tft.drawChar('2',80,40,20,RED);
void drawThreeWht() {
Tft.drawChar('3',80,40,20,WHITE);
void drawThreeRed() {
Tft.drawChar('3',80,40,20,RED);
