How do I make the backlight turn off without stoping code [SOLVED]
  RFID_Display
  @author RaskAttack
  Library:
  SPI.h
  MFRC522.h
  LiquidCrystal.h
  Servo.h
  pitches.h
  Most of this program is RFID. Anything that is not RFID will be marked.
#include <SPI.h>
#include <MFRC522.h>
#include <LiquidCrystal.h> //LCD
#include <Servo.h> //Servo
#include "pitches.h" //Buzzer
   // Other hardware pins
    const byte rstPin =  5;                // Reset pin
    const byte  ssPin = 53;                // Slave Select pin
    // Instantiate MFRC522 object class
    MFRC522 rfidReader(ssPin, rstPin);
    // Other Global Constants
    const long timeout = 30000;            // Timeout in ms
 *                      Global Variables                     *
    char* myTags[100] = {};
    int tagsCount = 0;
    String tagID = "";
bool readRFID(long _timeout=timeout, bool useTimeout=false){
    /*  readRFID will continuously check the RFID reader for the presence of
     *    a tag from and will attempt to get tag IDs. Updates global value
     *    tagID via getTagID function.
     *  Parameters:
     *    _timeout   - [optional] the length of time before functio gives up
     *                 default value = global timout value
     *    useTimeout - [optional] boolean to enforce timout period or wait
     *                 indefinately.  Default value = false.
     *  Returns:
     *    true  -  successfully reads tag ID
     *    false -  unsuccessful in reading the tag ID
    bool successRead = false;
    unsigned long startTime = millis();
    unsigned long currentTime = startTime;
    // S'U'+S'T'
    // T  = (currentTime-startTime) > timeout
    // T' = (currentTime-startTime) < timeout
    while (((successRead==false)&&(useTimeout==false)) || ((successRead==false)&&((currentTime - startTime) < _timeout))) {
        if (isTagPresent() == true){ successRead = getTagID(); }
        currentTime = millis();
    return successRead;
// include the library code:
// I2C library:
//#include <LiquidCrystal_I2C.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 8, en = 7, d4 = 23, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
#define BLUE 10 //RGB LED
#define GREEN 11 //RGB LED
#define RED 12 //RGB LED
#define back 43 //LCD
int redValue; //RGB LED
int greenValue; //RGB LED
int blueValue; //RGB LED
// I2C: use the line below
// Parameters: LCD address, number of columns = 16, and the number of rows = 2
//LiquidCrystal lcd(0x3F, 16, 2);
Servo myservo;
  // Normal begin statement for LCD requiring the number of columns and rows:
  lcd.begin(16, 2);
  pinMode(RED, OUTPUT); //RGB LED
  pinMode(GREEN, OUTPUT); //RGB LED
  pinMode(BLUE, OUTPUT); //RGB LED
  digitalWrite(RED, HIGH); //RGB LED
  digitalWrite(GREEN, LOW); //RGB LED
  digitalWrite(BLUE, LOW); //RGB LED
  pinMode(back, OUTPUT); //LCD
  digitalWrite(back, HIGH); //LCD
  myservo.attach(9);  //Servo
  myservo.write(50);  //Servo
  // Initiating
    Serial.begin(9600);                     // Start the serial monitor
    SPI.begin();                            // Start SPI bus
    rfidReader.PCD_Init();                  // Start MFRC522 object
    while (!Serial);                        // Do nothing if no serial port is opened
    // Obviously this is an over simplified sketch
    // Master tags would be save in flash storage and
    // retrieved here.  OR a special PIN entered to set
    // Master Tag.
    // But for the sake of simplicity, the sketch will
    // obtain a new master tag when restarted.
    // Prints the initial message
    lcd.clear(); //LCD
    lcd.setCursor(0, 0); //LCD
    lcd.print("-NO MASTER TAG!-"); //LCD
    lcd.setCursor(4, 1); //LCD
    lcd.print("SCAN NOW"); //LCD
    Serial.println(F("-NO MASTER TAG!-"));
    Serial.println(F("   SCAN NOW"));
    redValue = 255; //RGB LED
    greenValue = 191; //RGB LED
    blueValue = 0; //RGB LED
    analogWrite(BLUE, blueValue); //RGB LED
    analogWrite(RED, redValue); //RGB LED
    analogWrite(GREEN, greenValue); //RGB LED
    // readRFID will wait until a master card is scanned
    if (readRFID() == true) {
        myTags[tagsCount] = strdup(tagID.c_str()); // Sets the master tag into position 0 in the array
        lcd.clear(); //LCD
        lcd.print("Master tag set!"); //LCD
        Serial.println(F("Master tag set!")); //LCD
        redValue = 0; //RGB LED
        greenValue = 0; //RGB LED
        tagsCount++;
    printNormalModeMessage();
      //looks for keypresses
      //checks for any tags
     if (isTagPresent()==true){
        getTagID();
        checkTagID();
        delay(50);
        //return;
 *                         Functions                         *
bool isTagPresent(){
    /*  isTagPresent uses the MFRC522 methods to determine if
     *    a tag is present or the read card serial is enabled.
     *  Parameters: (none)
     *  Returns:
     *    true  - if tag detected or read card serial is true
     *    false - no tag detected or no read card serial true
    bool returnValue = true;
    // NOT a new PICC_IsNewCardPresent in RFID reader
    //OR
    // NOT a PICC_ReadCardSerial active in Serial
    if ( !rfidReader.PICC_IsNewCardPresent() || !rfidReader.PICC_ReadCardSerial() ) {
      returnValue = false;
    return returnValue;
byte checkMyTags(String tagID){
    /* checkMyTags function loops through the array of myTags
     *   Parameters:
     *     tagID    - a string to look for
     *   Returns:
     *     tagIndex - index in the array of myTags
     *                default 0
    byte tagIndex = 0;
    //Serial.println("checkMyTags Started");
    // Zero is reserved for master tag
    for (int i = 1; i < 100; i++) {
        if (tagID == myTags[i]) { tagIndex = i; }
    //Serial.println("checkMyTags ended");
    return tagIndex;
void checkTagID(){
    /* checkTagID check the tag ID for authorized tag ID values
     *   if Master tag found switch to program mode
     * Returns: (none)
    // Checks for Master tag
    if (tagID == myTags[0]) {
        // Switch to program mode
        lcd.clear(); //LCD
        lcd.setCursor(1, 0); //LCD
        lcd.print("Program mode:"); //LCD
        lcd.setCursor(1, 1); //LCD
        lcd.print("Add/Remove Tag"); //LCD
        Serial.println(F("Program mode"));
        Serial.println(F("Add/remove tag"));
        // Now with timeout
        // readRFID will skip if timeout exceeded
        if (readRFID(timeout,true)==true) {
            //Check for authorized tag
            byte tagIndex = checkMyTags(tagID);
            if (tagIndex!=0){
                //Remove existing tag
                myTags[tagIndex] = '\0';
                lcd.clear(); //LCD
                lcd.print("Tag romoved!");//LCD
                Serial.println(F("Tag Romoved!"));
                tagsCount--;
                //Not existing, add tag
                lcd.clear(); //LCD
                lcd.print("Tag added!"); //LCD
                Serial.println(F("Tag Added!"));
                tagsCount++;
            lcd.clear(); //LCD
            digitalWrite(back, LOW); //LCD
            lcd.print("Timeout!"); //LCD
            Serial.println(F("Timeout"));
        if (tagIndex!=0){
            //Authorized tag
            lcd.clear(); //LCD
            lcd.print("Access Granted!"); //LCD
            Serial.println(F(" Access Granted!"));
            greenValue = 255; //RGB LED
            myservo.write(150); //Servo
            tone(6, NOTE_C6); //Buzzer
            //Not authorized tag
            lcd.clear(); //LCD
            lcd.print("Access Denied!"); //LCD
            Serial.println(F(" Access Denied!"));
            tone(6, NOTE_C5); //Buzzer
            Serial.println(F(" New UID & Contents:"));
            rfidReader.PICC_DumpToSerial(&(rfidReader.uid));
bool getTagID() {
    /*  getTagID retrieves the tag ID.  Modifies global variable tagID
     *    Returns: true
    tagID = "";
    Serial.print(F(" UID tag: "));
    for (byte i = 0; i < rfidReader.uid.size; i++){
        // The MIFARE PICCs that we use have 4 byte UID
        Serial.print(rfidReader.uid.uidByte[i] < 0x10 ? " 0" : " ");
        Serial.print(rfidReader.uid.uidByte[i], HEX);
        // Adds the bytes in a single String variable
        tagID.concat(String(rfidReader.uid.uidByte[i] < 0x10 ? " 0" : " "));
        tagID.concat(String(rfidReader.uid.uidByte[i], HEX));
    tagID.toUpperCase();
    rfidReader.PICC_HaltA();                     // Stop reading
    return true;
void printNormalModeMessage() {
    /*  printNormalModeMessage sends the standard greeting
     *    to the serial monitor and LCD display.
     *  Returns: (none)
    delay(1500);
    noTone(6); //Buzzer
    myservo.write(50);// Servo
    lcd.clear(); //LCD
    lcd.print("Scan Your Tag!"); //LCD
    lcd.setCursor(7, 1); //LCD
    lcd.print(tagsCount - 1); //LCD
    Serial.println(F("-Access Control-"));
    Serial.println(F(" Scan Your Tag!"));
I am trying to make the backlight turn off while keeping the code running. I would also like the backlight to be turned off within 30s. Make sure that it only runs if the printNormalModeMessage is running. Thanks!
So you want to call this 30s after something else happens?
The problem is a lot like blink-without-delay, or Flashing multiple LEDs at the same time
  1. when the "something else happens" turn on the backlight and record the time
  2. check if the light has been on for a while, and turn it off
Completely untested snippet:
        getTagID();
        checkTagID();
        digitalWrite(back, HIGH); // turn on backlight when card present
        previousMillis = millis(); // record time the backlight turned on
        delay(50);
        //return;
        // check if the light has been on for a while:
        if(digitalRead(back) == HIGH && millis() - previousMillis >= 30000){
           digitalWrite(back, LOW); // turn off backlight
lcd.backlight(); // turn on backlight.
lcd.noBacklight(); // turn off backlight
These are the two commands I use.
Thank you!
I will be sure to try it!
That did not work for me, do you have an older version of the liquid crystal library?
