The following is my code for a setup, with my CANON Rebel and an amplified microphone into my arduino-board, as substitute for a remote-control, so that when the mic picks up a sound loud enough it
triggers the camera to take a picture. If there is none such sound, the camera will take a pic every 3 sec(3000) anyway. However, when run for about 30 secs or approximately 10 shoots the serial monitor and the whole code will just go berserk. Any idea why this happens? ? ? ?
Thanks!!!
THE CODE:
// these constants won't change:
const int micPin = 0; // the piezo is connected to analog pin 0
const int threshold = 1; // threshold value to decide when the detected sound is a knock or not
const int optoPin = 10; // the camera is connected to digital pin 10
const int shortest = 1000; // interval between pictures when the sound is lowest
const int longest = 3000; // interval between pictures when the sound is highest
// these variables will change:
int micRead = 0; // variable to store the value read from the sensor pin
int ledState = LOW; // variable used to store the last LED status, to toggle the light
// variables for the shutter interval timer
int shutterInterval = longest; // time between trigger / event
int oldTime = 0; // variable to hold the old time
pinMode(optoPin, OUTPUT); // sets the digital pin as output // Opto
Serial.begin(9600); // use the serial port
micRead = analogRead(micPin); // read the sensor and store it in the variable micLevel:
int shutterInterval = map(micRead, 0, 1023, longest, shortest);
// Serial.println(shutterInterval);
if(millis() - oldTime > shutterInterval){
oldTime = millis(); // define new oldTime
//takePic(shutterInterval); // take picture
Serial.println(micRead);
void takePic(int _printthis){
digitalWrite(optoPin, HIGH); // sets the OPTO on
// Serial.println(_printthis);
delay(300);
digitalWrite(optoPin, LOW); // sets the OPTP to off
We have the serial monitor going and in the beginning it returns values fine (each time the interval is reached), but after a certain amount of time, arduino prints values to the serial monitor constantly.
But it seemed to solve the problem to have it declared as a unsigned long, now we just have to fix a recurring problem with our mic :(
It appears you declared shutterInterval an int twice; once globally and once locally. I can't remember if that's allowed, or not...
[glow]int shutterInterval [/glow]= longest; // time between trigger / event
[glow]int shutterInterval [/glow]= map(micRead, 0, 1023, longest, shortest);
delay(300);
