I'm working on a big project with an Arduino Mega. A part of it is making video calls. I want to use a GSM module to make a video call. The video is going to be shown on a color screen. Is this possible? If yes how, if no is there any other module that can communicate with another Arduino over long distances through buildings, like 2 km? If yes, the video and sound will be sent to the other Arduino, which will show the video and sound. Or is there a GSM module or shield that supports a camera?
Thank you
Edit:
Making video calls with Arduino is near to impossible, but you can make normal calls with the esp32.
No. you won't likely achieve video/sound over GSM (2G) network with an Arduino.
Streaming a video requires probably at minimum a 3G network
A Low-definition video requires 500kbps which should be doable if you have a good 3G reception but you need an arduino capable of acquiring a pre-compressed stream, building and sending frames at that speed.. better quality requires 4G or 5G and a fast hardware...
why don't you get a pre-built surveillance camera with a built in 4G or 5G capability?
with GSM it's impossible if you want a minimum of quality. you just don't have the bandwidth
the farther you want to reach, the lower the speed of communication... so for real time audio+video it's hard...
if that were simple telephone operators would not need antennas and relays everywhere...
so you want to broadcast over a cellular network?... (some reading)
there are tons of different wireless way to send data between arduino
the type of technology you choose depends on the throughput you want and the distance and the type of environment in between the sender and the receiver.
the nrf24l01 doesnt have enough range, but the sa818 does. it has 5 km in open area, so it will probably do 2km in an area with buildings. let me do some research and see what I can do. maybe I can send video too. thanks for the idea
edit: I just realised that the sa818 costs 60 euros. i don't think I can use that. if I would, its going to cost twice the price it would actually cost if I used a gsm module or the hc-12.
speaking about the hc-12, it has 1 km range. so I don't think it would work. to make it work I would need to place multiple hc-12 as amplifiers on the way
The differance between RF reception in an 'open' area or good line of sight type locations and that in an urban area (with buildings) can be as much as 1000:1.
So if you a system that works at 5km line of sight you could get 100m or less in an area with buildings.
To run video calls over '2km' in an area 'with buildings' using typical Arduino RF modules I would say your chances are zero, maybe the military have some suitable equipment ?
Using GSM wil need multiple SIM cards, which need subscriptions.
I'm probably going to use a Wi-Fi module to connect to the internet to make calls.
here's an example:
for the code, if you want this to work over the internet, it will require some modification. you could look also at things like I2S (https://dronebotworkshop.com/esp32-i2s/), DMA stuff etc
This thread is about making video calls, remember? That requires 2-way video, so twice the band width and twice the processing power, twice the data handling capability.
