Hello, i have tried to figure out how to play a wav file on my Arduino Yun for a while, but it doesn`t seem to work at all. Can someone please help me with som examples of code or some tips towards what might work.
Thanks in advance!
Thanks in advance!
I would not try to play an audio file on an Arduino. It's a microcontroller. you use it to control things, like an audio player module. I would use one to control a Catalex YX-5300, my audio player of choice.
The [u]TMRpcm library[/u]can play 8-bit mono 32kHz (or lower) WAV files from an SD card.
The regular Arduinos don't have a DAC, so it's actually PWM. It's not true-analog (or PCM) and this can sometimes cause "issues" with amplifiers.
It also can't drive a regular 4 or 8-Ohm speaker or headphones, so you'll need an amplifier or "powered" speakers. (It can drive a piezo transducer/tweeter).
The regular Arduino isn't fast enough to decompress MP3 on-the-fly.
[quote author=Geek Emeritus link=msg=4377182 date=1574185269] Catalex YX-5300, my audio player of choice.
[/quote]
Isn't that the same chip that's in the DF Player Mini?
