Hi all,
I'm new to Arduino and pretty much a noob in electronics. So I got a Uno, a breadboard and some gear to start experimenting. I'm enjoying it so far and made some sensors work. Happy to get started and maybe even contribute eventually! ![]()
Anyway, I have got a 433Mhz radio circuit (it's called 3DR I think). And when I bought it it came with this weird cable like the thing on the left here:
except the end bit was super small (0.5mm across) and the cable had the same kind of thing on both ends, one with 4 pins (which fits nicely into the radio) and the other with 5 pins. My question is, how do I connect that 5-pin end to my breadboard? The thing is microscopic and none of the wire I have will fit into it ("obviously I'm doing this wrong" - me while randomly poking the thing with wires).
At the moment what I did was cut off the end bit and strip off the plastic at the end of the wires and connect them to my breadboard, and it works, but it's really flimsy as the wires easily come loose. Does anyone know what adapter I would use to convert that into 4 pins I can plug into my breadboard (or at least 4 wires)? I searched but there are so many types of cable and I have no idea what the one I'm looking for is called ![]()
BTW I don't have soldering equipment yet, but having looked around it seems to be a must-have for Arduino work.
Many thanks!
