How do I put an attiny1604 to sleep?
Hi guys, I would like to make my attiny 1604 to sleep for 10 minutes, I tried to modify the sketch found on: https://github.com/SpenceKonde/megaTinyCore/blob/master/megaavr/extras/PowerSave.md:
#include <avr/sleep.h>
void RTC_init(void)
  /* Initialize RTC: */
  while (RTC.STATUS > 0)
    ;                                   /* Wait for all register to be synchronized */
  RTC.CLKSEL = RTC_CLKSEL_INT32K_gc;    /* 32.768kHz Internal Ultra-Low-Power Oscillator (OSCULP32K) */
  RTC.PITINTCTRL = RTC_PI_bm;           /* PIT Interrupt: enabled */
  RTC.PITCTRLA = RTC_PERIOD_CYC16384_gc /* RTC Clock Cycles 16384, resulting in 32.768kHz/16384 = 2Hz */
  | RTC_PITEN_bm;                       /* Enable PIT counter: enabled */
ISR(RTC_PIT_vect)
  RTC.PITINTFLAGS = RTC_PI_bm;          /* Clear interrupt flag by writing '1' (required) */
  RTC_init();                           /* Initialize the RTC timer */
  pinMode(7, OUTPUT);                   /* Configure pin#7 as an output */
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);  /* Set sleep mode to POWER DOWN mode */
  sleep_enable();                       /* Enable sleep mode, but not going to sleep yet */
  sleep_cpu();                          /* Sleep the device and wait for an interrupt to continue */
  digitalWrite(7, CHANGE);              /* Device woke up and toggle LED on pin#7 */
by changing RTC_PERIOD_CYC16384 to a bigger number, but I cannot use something bigger than 32768.
I also tried to use cycles for repeating sleep_cpu(); but they don't work.
This should work.
for ( uint16_t i = 0 ; i < TIME_IS_UP ; ++i )
  sleep_cpu();
tf68:
This should work.
  sleep_cpu();
I don't get how it works, could you explain it better please?
You want to sleep the mcu for 10 minutes and the timer only allows you to sleep for 1 second at a time. You will need to repeatedly sleep, wake up and go back to sleep 600 times. You can do this by having the for statement loop 600 times.
  uint16_t SecondsToSleep = 600;
  for ( uint16_t i = 0 ; i < SecondsToSleep ; ++i )
    sleep_cpu();
} // loop
You can test the concept by setting SecondsToSleep to a smaller number. So that the change in the interval is easier to observe.
tf68:
    sleep_cpu();
} // loop
Thank you very much, I will test it tomorrow.
