how do I register noip using GET method with NodeMCU
  HTTPClient client;
  if (client.begin(noipServer, 80)) {
    Serial.println("Connected to noip");
    client.println("GET /nic/update?hostname=seaurchin.ddns.net HTTP/1.0");
    client.println("Host: dynupdate.no-ip.com");
    client.println("Authorization: seaurchin@gmail.com:secretPwd");
    client.println("User-Agent: San NodeMCU Client/0.0 seaurchin@gmail.com");
    client.println();
    //Wait for response
    while (client.connected())
      // stay in this loop until the server closes the connection
      while (client.available())
        // The server will not close the connection until it has sent the last packet
        // and this buffer is empty
        char read_char = client.read();
        Serial.write(read_char);
    // close your end after the server closes its end
    client.stop();
the above code is not working, I want to be able to notify no-ip server for ip address the NodeMCU client is running on
Where do you tell the noip server that?
Since I am using NodeMCU
I am using
#include <WiFiClient.h>
for the client object.
PaulS:
by first calling
and then sending header message I mentioned in my opening post.
Your Authorization string is not correct. Encode seaurchin@gmail.com:secretPwd to Base64 using online tool. And use the encoded string as below:
client.println("Authorization: Basic c2VhdXJjaGluQGdtYWlsLmNvbTpzZWNyZXRQd2Q=");
Here your encoded string is c2VhdXJjaGluQGdtYWlsLmNvbTpzZWNyZXRQd2Q=.
Regards,
Mustafa
