How do i send a CR without a LF?
Many years later, this still does not seem to be working.
Serial.println("Hello, Wo\rld!");
Should display as
ld!lo, Wo
instead of
Hello, Wo ld!
Is there any way to get the desired functionality of sending a separate CR to the Arduino serial monitor?
The Serial monitor does not support carriage return moving the print point to the start of the current line. Have you tried a terminal emulator such as PuTTY ?
Do not hijack. Thread split.
cmayer777: Is there any way to get the desired functionality of sending a separate CR to the Arduino serial monitor?
Why do you believe sending is the problem?
Sorry, but I mistakenly assumed Arduino's serial monitor should behave somewhat like a console window or any other terminal.
Thanks UKHeliBob, at least I now know I need to use a different serial monitor. PuTTY however, will not connect for some unknown reason, so I'll find others to try.
cmayer777: PuTTY however, will not connect for some unknown reason,
9 times in 10 when I use PuTTy, which isn't often, I forget to hit the Serial radio button and then forget to set the correct COMx value.
