The code i used to decompile my tv remote:
// Include the IRremote library header
#include <IRremote.h>
// Tell IRremote which Arduino pin is connected to the IR Receiver (TSOP4838)
int recvPin = 11;
IRrecv irrecv(recvPin);
// Configure the Arduino
void setup ( )
Serial.begin(9600); // Status message will be sent to PC at 9600 baud
irrecv.enableIRIn(); // Start the receiver
// Display IR code
void ircode (decode_results *results)
// Panasonic has an Address
if (results->decode_type == PANASONIC) {
Serial.print(results->address, HEX);
Serial.print(":");
// Print Code
Serial.print(results->value, HEX);
// Display encoding type
void encoding (decode_results *results)
switch (results->decode_type) {
default:
case UNKNOWN: Serial.print("UNKNOWN"); break ;
case NEC: Serial.print("NEC"); break ;
case SONY: Serial.print("SONY"); break ;
case RC5: Serial.print("RC5"); break ;
case RC6: Serial.print("RC6"); break ;
case DISH: Serial.print("DISH"); break ;
case SHARP: Serial.print("SHARP"); break ;
case JVC: Serial.print("JVC"); break ;
case SANYO: Serial.print("SANYO"); break ;
case MITSUBISHI: Serial.print("MITSUBISHI"); break ;
case SAMSUNG: Serial.print("SAMSUNG"); break ;
case LG: Serial.print("LG"); break ;
case WHYNTER: Serial.print("WHYNTER"); break ;
case AIWA_RC_T501: Serial.print("AIWA_RC_T501"); break ;
case PANASONIC: Serial.print("PANASONIC"); break ;
case DENON: Serial.print("Denon"); break ;
// Dump out the decode_results structure.
void dumpInfo (decode_results *results)
// Check if the buffer overflowed
if (results->overflow) {
Serial.println("IR code too long. Edit IRremoteInt.h and increase RAWBUF");
return;
// Show Encoding standard
Serial.print("Encoding : ");
encoding(results);
Serial.println("");
// Show Code & length
Serial.print("Code : ");
ircode(results);
Serial.print(" (");
Serial.print(results->bits, DEC);
Serial.println(" bits)");
void dumpRaw (decode_results *results)
// Print Raw data
Serial.print("Timing[");
Serial.print(results->rawlen-1, DEC);
Serial.println("]: ");
for (int i = 1; i < results->rawlen; i++) {
unsigned long x = results->rawbuf[i] * USECPERTICK;
if (!(i & 1)) { // even
Serial.print("-");
if (x < 1000) Serial.print(" ") ;
if (x < 100) Serial.print(" ") ;
Serial.print(x, DEC);
} else { // odd
Serial.print(" ");
Serial.print("+");
if (i < results->rawlen-1) Serial.print(", "); //',' not needed for last one
if (!(i % 8)) Serial.println("");
Serial.println(""); // Newline
void dumpCode (decode_results *results)
// Start declaration
Serial.print("unsigned int "); // variable type
Serial.print("rawData["); // array name
Serial.print(results->rawlen - 1, DEC); // array size
Serial.print("] = {"); // Start declaration
// Dump data
Serial.print(results->rawbuf[i] * USECPERTICK, DEC);
if ( i < results->rawlen-1 ) Serial.print(","); // ',' not needed on last one
if (!(i & 1)) Serial.print(" ");
// End declaration
Serial.print("};"); //
// Comment
Serial.print(" // ");
encoding(results);
Serial.print(" ");
ircode(results);
// Newline
Serial.println("");
// Now dump "known" codes
if (results->decode_type != UNKNOWN) {
// Some protocols have an address
Serial.print("unsigned int addr = 0x");
Serial.println(";");
// All protocols have data
Serial.print("unsigned int data = 0x");
// The repeating section of the code
void loop ( )
decode_results results; // Somewhere to store the results
if (irrecv.decode(&results)) { // Grab an IR code
dumpInfo(&results); // Output the results
dumpRaw(&results); // Output the results in RAW format
dumpCode(&results); // Output the results as source code
Serial.println(""); // Blank line between entries
irrecv.resume(); // Prepare for the next value
This is version 2.2.3 of IRremote library.
This is my TV remote decompiled:
Encoding : RC6
Code : C (20 bits)
Timing[41]:
+2600, - 950 + 400, - 900 + 400, - 450 + 450, - 450
+ 450, - 900 + 850, - 450 + 450, - 400 + 450, - 450
+ 450, - 450 + 400, - 450 + 450, - 450 + 450, - 450
+ 400, - 450 + 450, - 450 + 450, - 450 + 400, - 450
+ 450, - 450 + 850, - 450 + 450, - 900 + 450, - 400
+ 450
unsigned int rawData[41] = {2600,950, 400,900, 400,450, 450,450, 450,900, 850,450, 450,400, 450,450, 450,450, 400,450, 450,450, 450,450, 400,450, 450,450, 450,450, 400,450, 450,450, 850,450, 450,900, 450,400, 450}; // RC6 C
unsigned int data = 0xC;
Does anyone know how i can send raw data to basically power on my tv? Thanks in advance for the answers .
