How do I set up two different PWM's using the shift register.
I need to have two different PWM fades run in the background while other code runs. I want to be able to change the speed of the fade in and out using a potentiometer one per fade. I heard you can use the shift register for this, but I have no idea how.
This sounds like a classic case for the use of the BlinkWithoutDelay principle using 2 different interval tests. No need for a shift register.
I want to do a PWM fade not a blink.
So change the PWM value each time the interval has passed rather than turning the LED on or off. The BWD example sketch illustrates a principle not the exact solution to your problem.
jardane: I want to do a PWM fade not a blink.
Example there of a small library that does just that:
http://www.gammon.com.au/forum/?id=11411&reply=1#reply1
Scroll down to "Example fading sketch".
