I have been trying to run a servo in slow rotation from 0 to 180 by pushing a push button once and then by using the same push button, when pressed again the servo will slowly rotate from 180 to 0. I have gotten the servo to work at normal speed fine, but when I put the sweep program in it, the servo continuously keeps going from 180 to 0 without stopping.
HERE IS THE WORKING CODE
#include <Servo.h>
Servo myservo; // create servo object to control a servo
#define servoPin 6 //~
#define pushButtonPin 8
int val = 0; // push value from pin 2
int angle =180; // initial angle for servo (beteen 1 and 179)
Servo servo3;
int buttonPushed =0;
int pos = 0;
int lightON = 0;//light status
int pushed = 0;//push status
Serial.begin(9600); // setup serial
myservo.attach(servoPin);
servo3.attach(5); // attaches the servo on pin 3 to the servo object
pinMode(pushButtonPin,INPUT_PULLUP);
Serial.println(" Servo Button ");
myservo.write(angle);//initial position
val = digitalRead(pushButtonPin);// read the push button value
if(val == HIGH && lightON == LOW){
pushed = 1-pushed;
delay(100);
lightON = val;
if(pushed == HIGH){
Serial.println("Light ON");
servo3.write(0); // tell servo to go to position in variable 'pos'
delay(100); // waits 15ms for the servo to reach the position
if(pushed == LOW){
Serial.println("Light OFF");
servo3.write(180); // tell servo to go to position in variable 'pos'
HERE IS THE CODE I AM HAVING TROUBLE WITH
String readString = "";
#include "AFMotor.h"
#include <Servo.h>
Servo servo3;
int pos = 0;
while (Serial.available()) {
char c = (char)Serial.read();
readString += c;
pushed = 1-pushed;
delay(100);
lightON = val;
if(pushed == HIGH){
for (int i = 0; i<110; i++){
servo3.write(i); // waits 15ms for the servo to reach the position
delay(10);
if(pushed == LOW){
for (int j = 110; j>0; j--){
servo3.write(j); // tell servo to go to position in variable 'pos'
delay(10); // waits 15ms for the servo to reach the position
You seem to be unaware of some very basic things that you should learn and to take care of.
you should use pressing ctrl-T for autoformatting your code
In C++ all code must be inside of functions.
Your "not working code" has a part that is outside of function loop
This code does not even compile.
So if you describe the behaviour as "continually sweeping" the cause might be that compiling your latest code failed and was aborted and some earlier code ist still running
In C++ each opening curly brace must have a corresponding closing curly brace
I have commented all your braces with letters "A,B,C,D,E ....
to make you see this
If you use ctrl-t for autoformatting you will see that there are three curly braces most left
and that your if-condition is below the most left closing brace
#include <Servo.h>
int angle = 180; // initial angle for servo (beteen 1 and 179)
Servo servo3;
int buttonPushed = 0;
int pos = 0;
pinMode(pushButtonPin, INPUT_PULLUP);
void loop() { //A
while (Serial.available()) { // B
readString += c;
} //B
if (val == HIGH && lightON == LOW) { // C
pushed = 1 - pushed;
delay(100);
} //C
lightON = val;
if (pushed == HIGH) { //D
for (int i = 0; i < 110; i++) { //E
delay(10);
} //E
} //D
} // A XXX curly brace that marks END function loop()
// outside any function
if (pushed == LOW) { // F
for (int j = 110; j > 0; j--) { // G
} // G
}// F
} // no opening brace
It is easy to understand and has a good mixture between explaining important concepts and example-codes to get you going. So give it a try and report your opinion about this tutorial.
thank you for the advice. I made the adjustments and removed unnecessary parts from the code. but it is still running continuously on the first IF when given power even without pressing button.
#include <Servo.h>
Servo servo3;
int pos = 0;
pushed = 1-pushed;
delay(100);
lightON = val;
if(pushed == HIGH){
delay(10);
if(pushed == LOW){
it goes from 0 to 110 again and again without stopping. can somebody please tell me how I can make the servo go from 0 to 110 slowly once when the button is pressed once , and go from 110 to 0 slowly when pressed again?
#include <Servo.h>
Servo servo3;
const byte pushButtonPin = 8;
int pos = 0;
bool buttonPushed = 0;
bool lightON = 0;//light status
bool pushed = 0;//push status
if (digitalRead(pushButtonPin) == LOW) {
if (pos == 0) {
delay(10);
pos = 110;
else {
pos = 0;
thank you for fixing my code. but I want this code to open and close a door. when pushed once the door will open slowly and stay open. then when the button is pushed again the door will close slowly and stay closed. is this possible? can you please help me. i have been working on this for days.
ok fixed one problem. now after going to 110 it stays there. but when the button is pushed again. it just comes directly to 0 and again slowly comes to 110. I think the code is only making the servo go 0 to 110 but not the other way
#include <Servo.h>
int pos = 0;
Servo servo3;
if (pos == 0) {
delay(10);
pos = 110;
else {
pos = 0;
pos = 110;
