How do I update the baud rate from 115200 to 9600?
void main()
  while(1)
    UART1_Init(115200);
    UART1_Write_Text("test");
    Delay_ms(1000);
    UART1_Init(9600);
    Delay_ms(1000);
main?? UART1_Init ?? Delay_ms??
On the arduino you would do something like
    Serial.begin (115200);
    Serial.print ("test");
    delay (1000);
    Serial.begin (9600);
    delay (1000);
Would you need a Serial.end in between there?
I'm sure you would want a flush before you change the baud or it would all end up going out at 9600.
EDIT: I guess the delay solves that.
Try it and see - the delays will drain the outgoing queue, incoming is another matter. Changing
baud rate dynamically involves having to think carefully about such things.
