How do i upload a library to the arduino cloud editor
I’m trying to write a sketch to control a Lidar called TF-Luna on the arduino cloud editor, for that i need to use a library.
The library i mention i got it from here:
Also i have already read these posts but i was unsuccesful; i don’t know if the presented instructions work only for a sheild’s library.
https://support.arduino.cc/hc/en-us/articles/360011890519-Import-your-sketchbook-and-libraries-to-the-Cloud-Editor
Any help will be apreciated.
Hi @bistroncium. All the libraries in the Arduino Library Manager are preinstalled in Arduino Cloud. This means that you only need to upload a library to your Arduino Cloud account when one of the following situations occurs:
  • the author of the library has not already added the library to the Library Manager system
  • the library is in Library Manager, but you need to work with a beta test version of the library that was not released to Library manager
This "TFLI2C" library has already been added to Library Manager, and use of a beta test version of the library would only be needed in specific advanced use cases. So there is no need for you to upoad the library to Arduino Cloud. Just carry on with your project. You can use the "TFLI2C" library in your sketch and when you compile the sketch, the preinstalled library will be used.
So give it a try and let us know if you have any problems.
Great! it worked, thank you
You are welcome. I'm glad it is working!
Regards, Per
It seems the Arduino Cloud editor requires every custom library to have a library.properties file before it can be uploaded. Without that file, the system won’t recognize the library as valid. Adding a simple properties file with the name, version, and author often fixes the issue.
The library must have this file before it will be accepted into the Arduino Library Manager, so every file in Library Manager already meets this requirement, including the "TFLI2C" library @bistroncium was attempting to use.
The only time you need to worry about the library.properties file is if you are trying to use a library that is not already in Library Manager. In this case, you might well find that the library doesn't already have such a file and need to add one before importing the library to your Arduino Cloud account, as occurred in the referenced forum topic Uploading Library to Arduino Cloud.
