I am using GRBL 1.1 to do some motion control for a prototype medical device at work. I am familiar with GCODE in general having built my own printer and milling CNC. I decided to install GRBL and drive it with my own custom interface (Labview) because I can prototype the motion sequences more easily before hard-coding them into dedicated firmware (that was the idea anyway)
Anyway, I have an atypical homing requirement: I have a rotary positioner that has a central safe position and no room for +/- limit switches. I put a photo detector in place that sees a disk on the motor shaft that is half black and half white. If it sees black it turns one way, otherwise the opposite. This keeps the motor moving along the shortest path to the center. This kind of homing location is intrinsically reliable but not useful for things like CNC or printing where an outer boundary must be defined.
While trying to build my own (slow) homing routine I needed the limit-switch positions but my mask is not working properly. I set $10=17 for only machine position and pin status, but it behaves like this:
8 times in a row it reports <Idle|MPos:0.000,0.000,0.000|FS:0,0>
The 9th time it reports <Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
The 10th time it reports <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
Then the cycle repeats, regardless of the mask setting. Setting $10=31 will also insert Bf: values but still no limit values.
As Neil Armstrong said when he first stepped on the moon onto some chewing gum...'wtf?'
Here is the build info:
[VER:1.1h.20190830:]
[OPT:V,15,128]
thanks
