How do i use bitread correctly?
i try to use bitread in my program but it doesn't work, It just gives a bunch of 0-oes
here is my program:
for (int i = 0; i < 14; i++) {
int b = bitRead(addr, i);
if (b==0) {
digitalWrite(ADDR, LOW);
digitalWrite(ADDR, HIGH);
digitalWrite(CLK, HIGH);
delay(1);
digitalWrite(CLK, LOW);
Your code is incomplete.
Please remember to use code tags when posting code
Description
Reads a bit of a number.
Syntax
bitRead(x, n)
Parameters
x: the number from which to read.
n: which bit to read, starting at 0 for the least-significant (rightmost) bit.
Returns
The value of the bit (0 or 1).
If you are trying to read the Ith bit from 0-14 of the variable ADDR, then this is correct, but I think you might be trying to read the word at ADDR instead, correct?
I realized that i only had 0 as addres in the rest of my code
Just like this
xEventGroupWaitBits (eg, evtParseMQTT, pdTRUE, pdTRUE, portMAX_DELAY ); //
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
    mqttOK = 0;
does not mean much to you, this
does not mean much to me.
Post all your code, please.
Glad you figured it out. :smiley:
Post more of your code next time and someone else can probably help you spot issues like that.
