how do I use ELM327.h library?
Hi, Guys!
I have an ELM327 type OBD II interface, and an Arduino MEGA 2560 board. I'd like to display my car's fuel level value (percent).
I've found following rows inside ELM327.cpp:
byte Elm327::fuelLevel(byte &level){
byte status;
byte values[1];
status=getBytes("01","41","2F",values,1);
if (status != ELM_SUCCESS){
return status;
level= (100 * values[0])/255;
return ELM_SUCCESS;
// PID 2F Fuel level in %
Can You help me, how do I use this function in an .ino file as reading fuel level value?
Thanks: rcph
Please provide a link to where you got the ELM327 library
Create an instance of the ELM327 class, unless that method is static.
ELM327 someInstanceName(whatever values you need to supply);
Then, in loop():
   byte fuelPercent = 0;
   someInstanceName.fuelLevel(fuelPercent);
   // do whatever you want to do with fuelPercent
PaulS:
Then, in loop():
Maybe better:
  if (someInstanceName.fuelLevel(fuelPercent) == ELM_SUCCESS)
    // Do something with fuelPercent
Hi, Everybody!
Thank You very much YOur help! :slight_smile:
rcph
