How do I use multiple headers files in subfolders with Arduino?
So I have multiple files in my project (a simple Blink project) but I’m learning OOP w/ C++ so I’d like to use multiple files and subfolders. I can’t seem to understand why I get the error:
/home/zastrix/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: sketch/src.ino.cpp.o:(.text.loop+0x8): undefined reference to `Blink::Blink(int, bool)'
/home/zastrix/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: sketch/src.ino.cpp.o:(.text.loop+0xc): undefined reference to `Blink::toggleOn()'
/home/zastrix/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: sketch/src.ino.cpp.o:(.text.loop+0x10): undefined reference to `Blink::~Blink()'
/home/zastrix/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: sketch/src.ino.cpp.o:(.text.loop+0x27): undefined reference to `Blink::Blink(int, bool)'
/home/zastrix/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: sketch/src.ino.cpp.o: in function `loop':
/home/zastrix/Documents/Personal/Arduino/oop-led/src/src.ino:13: undefined reference to `Blink::toggleOn()'
Here’s the code:
Main file:
#include <ESP8266WiFi.h>
#include "blink/Blink.h"
    while(!Serial.available()) {};
    Blink blink(16);
    Serial.write("Toggling on...\n");
    blink.toggleOn();
    Serial.write("Deleting...\n");
Blink.h:
#ifndef BLINK_H
#define BLINK_H
class Blink
    private:
        int pin;
        bool status, inverted;
    public:
        Blink(int pin, bool inverted = false);
        void toggleOn();
        void toggleOff();
        ~Blink();
#endif
Blink.cpp:
// Gotta include this for ESP8266 support.
#include "Blink.h"
Blink::Blink(int pin, bool inverted)
    this -> pin = pin;
    this -> inverted = inverted;
    pinMode(pin, OUTPUT);
void Blink::toggleOn()
    digitalWrite(pin, inverted ? HIGH : LOW);
    status = true;
void Blink::toggleOff()
    digitalWrite(pin, inverted ? LOW : HIGH);
    status = false;
Blink::~Blink()
    toggleOff();
And this is my tree:
src
├── blink
│   ├── Blink.cpp
│   └── Blink.h
└── src.ino
Edit:
I can make this work in one-big folder but I’d like to separate them into folders so I can get the grasp of it.
The IDE just isn’t that smart.
First, the folder "blink" should really be "Blink", to match the .h/.cpp files contained therein. Case matters.
Here's what I do, that at least works.
SomeSketch
SomeSketch.ino
src
SomeInclude
SomeInclude.h
SomeInclulde.cpp
SomeOtherInclude
SomeOtherInclude.h
SomeOtherInclulde.cpp
The #include in the .ino file must be:
#include "src/SomeInclude/SomeInclude.h"
If SomeInclude needs to reference SomeOtherInclude, it must include it as:
#include "../SomeOtherInclude/SomeOtherIncude.h"
Regards,
Ray L.
