How do I use the KY-039 sensor?
Hi there,
I'm very new to the arduino and it's sensors. I was hoping you could help me out a little.
I'm trying to measure the heartbeat with the KY-039 sensor:
So, my question is how would I set this up with the arduino Uno and a breadboard so I can read out the data? And where can I find a console that let me read out this data?
Thanks in advance! :slight_smile:
UKHeliBob on this very forum suggests:
Try the code on this page
http://www.ebay.co.uk/itm/NEW-KY-039-Finger-Measuring-Heartbeat-Sensor-Module-for-Arduino-/331127966386
bigred1212:
Thanks for you answer.
I have tried that code, but all I get is data that is around 1000. That is, if I'm looking in the right place. It doesn't change when I place my finger on the sensor. I also tried to shield it from light, but no luck.
I couldn't find the answer in this thread: KY039 Arduino Heart rate code - Programming Questions - Arduino Forum
So, perhaps I might be setting it up wrong. Or do you think it has to do with something else?
TerraroQ:
Looking from the top as "Keyes" reads, left pin signal, middle Vcc, right Gnd?
hey, I have the same problem.
in the example code it state that pin 13 should be blinking but it doesn't :confused:
I have tried so many things i even used another module because i thought mine is not working.
what I do is: I put my finger between the transmitter and receiver, is that wrong?
also i connect the "S" to A0 and the middle pin to +5 v and the last one to GND.
I have a couple of these and have never been able to get them to work.
I sell a lot of the Keyes Electronic Bricks and they are good and good value, but I decided to NOT sell this one! If anyone gets it to work, PLEASE tell us how.
Some perspective on the Brick Stuff HERE:
DISCLAIMER: Mentioned stuff from my own shop..!
I had the same question and it seemed most people said this sensor module just doesn't work.
I fooled around with the connections and managed to make a blob pulse according to my pulse with processing.
(it's quite subtle but it's mostly in synch with my pulse)
Arduino Code:
I used the one recommended earlier in this thread
Made a simple Processsing code:
(I'm a beginner, pls advise if something's off ^^;)
void setup(){
myPort = new Serial(this, Serial.list()[6], 115200);
size(300, 300);
background(0);
noStroke();
smooth();
void draw() {
while (myPort.available() > 30) {
int inByte = myPort.read();
println(inByte);
if(inByte>35){
ellipse(width/2, height/2, inByte2, inByte2);
else{
background(0);
Connections:
Most importantly, I connected the A0 to the S pin & Ground to - pin.
Leaving out the whole 5V all together. (why, I hv no clue. the pin fell out and it worked better without too much flickering)
Should there be light coming from the Led when you apply power to the sensor?
johnjameson:
No. It's infrared light so invisible to the naked eye, but you should be able to see it using a digital camera.
Hi!! I see this code only works for detecting the heartbeat but i want to calculate heart rate.Can you please suggest me the code
