How do I use the Wii Nunchuck on the Pro Mini?
I’m trying to use the Wii Nunchuck library http://todbot.com/blog/2008/02/18/wiichuck-wii-nunchuck-adapter-available/ on the Pro Mini but the library uses data pins A4 and A5 while the Pro Mini doesn’t have them accessable. Does anyone know how to modify the library to use the I2C on different pins (maybe A2/A3)?
Library:
 * Nunchuck functions  -- Talk to a Wii Nunchuck
 * This library is from the Bionic Arduino course :
 *                          http://todbot.com/blog/bionicarduino/
 * 2007-11 Tod E. Kurt, http://todbot.com/blog/
 * The Wii Nunchuck reading code originally from Windmeadow Labs
 *   http://www.windmeadow.com/node/42
#if (ARDUINO >= 100)
#include <Arduino.h>
#else
#include <WProgram.h>
//#define Wire.write(x) Wire.send(x)
//#define Wire.read() Wire.receive()
#endif
static uint8_t nunchuck_buf[6];   // array to store nunchuck data,
// Uses port C (analog in) pins as power & ground for Nunchuck
static void nunchuck_setpowerpins()
#define pwrpin PORTC3
#define gndpin PORTC2
 //   DDRC |= _BV(pwrpin) | _BV(gndpin);
 //   PORTC &=~ _BV(gndpin);
 //   PORTC |=  _BV(pwrpin);
 //   delay(100);  // wait for things to stabilize
// initialize the I2C system, join the I2C bus,
// and tell the nunchuck we're talking to it
static void nunchuck_init()
    Wire.begin();                // join i2c bus as master
    Wire.beginTransmission(0x52);// transmit to device 0x52
    Wire.write((uint8_t)0x40);// sends memory address
    Wire.write((uint8_t)0x00);// sends sent a zero.
#else
    Wire.send((uint8_t)0x40);// sends memory address
    Wire.send((uint8_t)0x00);// sends sent a zero.
#endif
    Wire.endTransmission();// stop transmitting
// Send a request for data to the nunchuck
// was "send_zero()"
static void nunchuck_send_request()
    Wire.write((uint8_t)0x00);// sends one byte
#else
    Wire.send((uint8_t)0x00);// sends one byte
#endif
// Encode data to format that most wiimote drivers except
// only needed if you use one of the regular wiimote drivers
static char nunchuk_decode_byte (char x)
    x = (x ^ 0x17) + 0x17;
    return x;
// Receive data back from the nunchuck,
// returns 1 on successful read. returns 0 on failure
static int nunchuck_get_data()
    int cnt=0;
    Wire.requestFrom (0x52, 6);// request data from nunchuck
    while (Wire.available ()) {
        // receive byte as an integer
        nunchuck_buf[cnt] = nunchuk_decode_byte( Wire.read() );
#else
        nunchuck_buf[cnt] = nunchuk_decode_byte( Wire.receive() );
#endif
        cnt++;
    nunchuck_send_request();  // send request for next data payload
    // If we recieved the 6 bytes, then go print them
    if (cnt >= 5) {
        return 1;   // success
    return 0; //failure
// Print the input data we have recieved
// accel data is 10 bits long
// so we read 8 bits, then we have to add
// on the last 2 bits.  That is why I
// multiply them by 2 * 2
static void nunchuck_print_data()
    static int i=0;
    int joy_x_axis = nunchuck_buf[0];
    int joy_y_axis = nunchuck_buf[1];
    int accel_x_axis = nunchuck_buf[2]; // * 2 * 2;
    int accel_y_axis = nunchuck_buf[3]; // * 2 * 2;
    int accel_z_axis = nunchuck_buf[4]; // * 2 * 2;
    int z_button = 0;
    int c_button = 0;
    // byte nunchuck_buf[5] contains bits for z and c buttons
    // it also contains the least significant bits for the accelerometer data
    // so we have to check each bit of byte outbuf[5]
    if ((nunchuck_buf[5] >> 0) & 1)
        z_button = 1;
    if ((nunchuck_buf[5] >> 1) & 1)
        c_button = 1;
    if ((nunchuck_buf[5] >> 2) & 1)
        accel_x_axis += 1;
    if ((nunchuck_buf[5] >> 3) & 1)
        accel_x_axis += 2;
    if ((nunchuck_buf[5] >> 4) & 1)
        accel_y_axis += 1;
    if ((nunchuck_buf[5] >> 5) & 1)
        accel_y_axis += 2;
    if ((nunchuck_buf[5] >> 6) & 1)
        accel_z_axis += 1;
    if ((nunchuck_buf[5] >> 7) & 1)
        accel_z_axis += 2;
    Serial.print(i,DEC);
    Serial.print("\t");
    Serial.print("joy:");
    Serial.print(joy_x_axis,DEC);
    Serial.print(",");
    Serial.print(joy_y_axis, DEC);
    Serial.print("  \t");
    Serial.print("acc:");
    Serial.print(accel_x_axis, DEC);
    Serial.print(",");
    Serial.print(accel_y_axis, DEC);
    Serial.print(",");
    Serial.print(accel_z_axis, DEC);
    Serial.print("\t");
    Serial.print("but:");
    Serial.print(z_button, DEC);
    Serial.print(",");
    Serial.print(c_button, DEC);
    Serial.print("\r\n");  // newline
    i++;
// returns zbutton state: 1=pressed, 0=notpressed
static int nunchuck_zbutton()
    return ((nunchuck_buf[5] >> 0) & 1) ? 0 : 1;  // voodoo
static int nunchuck_cbutton()
    return ((nunchuck_buf[5] >> 1) & 1) ? 0 : 1;  // voodoo
// returns value of x-axis joystick
static int nunchuck_joyx()
    return nunchuck_buf[0];
// returns value of y-axis joystick
static int nunchuck_joyy()
    return nunchuck_buf[1];
// returns value of x-axis accelerometer
static int nunchuck_accelx()
    return nunchuck_buf[2];   // FIXME: this leaves out 2-bits of the data
// returns value of y-axis accelerometer
static int nunchuck_accely()
    return nunchuck_buf[3];   // FIXME: this leaves out 2-bits of the data
// returns value of z-axis accelerometer
static int nunchuck_accelz()
    return nunchuck_buf[4];   // FIXME: this leaves out 2-bits of the data
http://arduino.cc/en/Main/ArduinoBoardProMini#.UwqRPhAZ65Q
The Pro Mini has 8 analog inputs, each of which provide 10 bits of resolution (i.e. 1024 different values). Four of them are on the headers on the edge of the board; two (inputs 4 and 5) on holes in the interior of the board.
So, I don't understand your statement:
but the library uses data pins A4 and A5 while the Pro Mini doesn't have them accessable.
The I2C pins are defined by Atmel for the chip. You could think about bit-banging I2C, but it wouldn't be anywhere near as fast.
Turns out I'm an idiot, the pins are accessible, just not put on the edge pins! Since I2C allows multiple devices to be hooked up together is it possible to hook up another Wii Nunchuck? Or would they start yelling over each other?
magruder13: Turns out I'm an idiot, the pins are accessible, just not put on the edge pins! Since I2C allows multiple devices to be hooked up together is it possible to hook up another Wii Nunchuck? Or would they start yelling over each other?
As you have realized the A4 & A5 pins exist on the pro mini and they are used for I2C. I don't think you will be able to connect 2 Nunchucks to the same arduino without a I2C multiplexer chip like this as they will probably have the same I2C address and clash.
I don’t think you will be able to connect 2 Nunchucks to the same arduino without a I2C multiplexer chip like this as they will probably have the same I2C address and clash.
That’s the answer I assumed I was going to get. Thanks for your help!
