Hello,
Is there any explanation for the meaning behind the CPP files and H files for this code? Which file/lines of code would I have to modify to change Dobot's programmed movement? I don't have a lot of programming experience but I do understand ARDUINO a little bit.
Welcome to the forum
Your topic was MOVED to its current forum category as it is more suitable than the original as it is not an Introductory Tutorial
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
I have a dobot magician hand robot. however, I'm having trouble with the coding part. I'm not sure what the correct codes will be. Can you help me with the blockly code part?
