How do I use variables from another function?
Hi, I want to use variables (all the floats) from the "void loop" function in the "void temperatuur_actie"
Because when I compile it now it says thath the variables are not declared
#include <Wire.h>
#include <DS3232RTC.h>
#include <dht.h>
#include <Stepper.h>
#include <TimeLib.h>
#define DHT11_PIN 7
int val;
const int relais_warmte = 6;
const int stappen_per_draai = 285; // 1000 stappen = 3,5 toeren -> 1 toer = 285 stappen
byte stappen_teller = 0;
Stepper myStepper(stappen_per_draai, 8, 9, 10, 11);
dht DHT;
  myStepper.setSpeed(30);
  pinMode(relais_warmte, OUTPUT);
  RTC.set(now());
  setSyncProvider(RTC.get);
    if(timeStatus() != timeSet)
        Serial.println("Unable to sync with the RTC");
       Serial.println("RTC has set the system time");
 if ( val >= 5 && val <= 19){
    float VerwarmingLaagsteTemp = 18.7;
    float VerwarmingHoogsteTemp = 19.3;
    float RaamLaagsteTemp = 25.7;
    float RaamHoogsteTemp = 26.3;
    temperatuur_actie();
   else{
    float VerwarmingLaagsteTemp = 12.7;
    float VerwarmingHoogsteTemp = 13.3;
    float RaamLaagsteTemp =18.7;
    float RaamHoogsteTemp = 19.3;
void temperatuur_actie(){
    int chk = DHT.read11(DHT11_PIN); //Er wordt gelezen vanuit de sensor welke temperatuur het is
    Serial.print("Temperatuur = "); // Temperatuur = x
    Serial.println(DHT.temperature);
    delay(1000); //Wacht 1 second
    if (chk < VerwarmingLaagsteTemp) {
      digitalWrite(relais_warmte, HIGH);
    if (chk > VerwarmingHoogsteTemp) {
      digitalWrite(relais_warmte, LOW);
    if (chk > RaamHoogsteTemp) {
      myStepper.step(stappen_per_draai);
      stappen_teller = 1;
    if (chk < RaamLaagsteTemp) {
      myStepper.step(-stappen_per_draai);
      stappen_teller = 0;
you can make them global and then you see them everywhere or modify the function to pass them as parameters
global:
#include <Wire.h>
#include <dht.h>
#define DHT11_PIN 7
int val;
float VerwarmingLaagsteTemp;
float VerwarmingHoogsteTemp;
float RaamLaagsteTemp;
float RaamHoogsteTemp;
dht DHT;
  RTC.set(now());
  if (timeStatus() != timeSet)
  if ( val >= 5 && val <= 19) {
  else {
    RaamLaagsteTemp = 18.7;
void temperatuur_actie() {
    stappen_teller = 1;
    stappen_teller = 0;
if you want a function with parameters
#include <Wire.h>
#include <dht.h>
#define DHT11_PIN 7
int val;
dht DHT;
  RTC.set(now());
    temperatuur_actie(18.7, 19.3, 25.7, 26.3);
    temperatuur_actie(12.7, 13.3, 18.7, 19.3);
void temperatuur_actie(float VerwarmingLaagsteTemp, float VerwarmingHoogsteTemp, float RaamLaagsteTemp, float RaamHoogsteTemp) {
    stappen_teller = 1;
    stappen_teller = 0;
of course all this is totally useless as val is not really defined and as global will be 0, so your loop will never enter the first if and will always execute the second part.
J-M-L:
you can make them global and then you see them every where or modify the function to pass them as parameters
global:
#include <Wire.h>
#include <dht.h>
#define DHT11_PIN 7
int val;
dht DHT;
RTC.set(now());
else {
   stappen_teller = 1;
   stappen_teller = 0;
#include <Wire.h>
#include <dht.h>
#define DHT11_PIN 7
int val;
dht DHT;
RTC.set(now());
   stappen_teller = 1;
   stappen_teller = 0;
Thank you! And yes val is currently useless but I need to add val = (hour()); to change the value of val.
Happy if it helps
you might want to read about variable scope to understand this better
have fun
