Well.....thanks for all the replies.
I have two led strips and for some reason both of them fail to light the first 4 leds? they are
64, 0, 0, 0, 0
128, 0, 0, 0, 0
0, 1, 0, 0, 0 and
0, 2, 0, 0, 0
at least those 4 do nothing so I assume they are the addresses of the first four LED's
Paul, I tried to make a sketch from what you offered
const byte ledPin[40] = {18, 19, 20, 21, 22, 23, 32, 33, 34, 35, 36, 37, 10, 11, 38, 39, 24, 25, 12, 13, 14, 15, 26, 27, 28, 29, 0, 1, 2, 3, 30, 31, 16, 17, 4, 5, 6, 7, 8, 9};
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
for (int x=0;x < 40; x++)
byte pin = ledPin[x];
byte sr = pin >> 3;
byte srBit = pin & 7;
byte shiftBytes[5] = {0, 0, 0, 0, 0};
bitWrite(shiftBytes[sr], srBit, 1);
digitalWrite(clockPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, srBit);
delay(30);
Serial.print (srBit);
Serial.print (" ");
Serial.println (x);
digitalWrite (latchPin,HIGH);
digitalWrite (latchPin,LOW);
delay(2000);
but couldn't work out what to call in the shiftout line, at least I think that is my problem.
J-M-L jackson, I took your sketch and altered some of it especially the loop function, I turned it into a 'for' loop
const byte dataPin = 11;
const byte clockPin = 12;
const byte latchPin = 8;
byte ledPatterns[40][5] =
{64,0,0,0,0},{128,0,0,0,0},{0,1,0,0,0},{0,2,0,0,0},
{0,0,4,0,0},{0,0,8,0,0},{0,0,16,0,0},{0,0,32,0,0},{0,0,64,0,0},
{0,0,128,0,0},{0,0,0,0,1},{0,0,0,0,2},{0,0,0,0,4},{0,0,0,0,8},
{0,0,0,0,16},{0,0,0,0,32},{0,4,0,0,0},{0,8,0,0,0},{0,0,0,0,64},
{0,0,0,0,128},{0,0,0,1,0},{0,0,0,2,0},{0,16,0,0,0},{0,32,0,0,0},
{0,64,0,0,0},{0,128,0,0,0},{0,0,0,4,0},{0,0,0,8,0},{0,0,0,16,0},
{0,0,0,32,0},{1,0,0,0,0},{2,0,0,0,0},{4,0,0,0,0},{8,0,0,0,0},
{0,0,0,64,0},{0,0,0,128,0},{0,0,1,0,0},{0,0,2,0,0},{16,0,0,0,0},
{32,0,0,0,0}
// shadow array holds current state of all 5 shift registers
byte shadow[5] = {0,0,0,0,0};
void setLED(int pinNumber, bool state)
for(int i = 0; i < 5; i++)
if(state) shadow[i] |= ledPatterns[pinNumber][i];
else shadow[i] &= ~ledPatterns[pinNumber][i];
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, shadow[i]);
digitalWrite(latchPin, HIGH);
for(int i = 0; i < 40; i++)
setLED(i, HIGH);
delay(100);
setLED(i, LOW);
delay(10);
It now works quite well.
KenB4, I altered some of the sketch to make it work but again I think I am calling the wrong thing in the shiftout line
enum Chip : byte {_1ST = 1, _2ND, _3RD, _4TH, LAST};
struct Foo { // no idea what to call this
Chip chip;
byte value;
Foo leds[] = {
{_3RD, 252},
{_4TH, 63},
{_2ND, 12},
{LAST, 0b11000000}, // or use the bits directly
void doWhatever()
for (Foo &f : leds)
{ // loop through them all
Serial.print(f.chip);
Serial.print('\t');
Serial.println(f.value);
bool firstBit = false;
for (int m = 0; m < 8; m++)
byte mask = 1 << m;
if (mask > f.value)
break;
byte bit = f.value & mask;
if (bit || firstBit)
firstBit = true;
for (int c = _1ST; c <= LAST; c++)
{ // easy to reverse chip order
Serial.print(f.chip == c ? bit : 0); // replace with shiftOut()
shiftOut(dataPin, clockPin, MSBFIRST, bit);
Serial.print(c == LAST ? '\n' : '\t');
delay(250);
doWhatever();
delay(2500);
J-M-L jackson, this one almost works, it does a full sweep but then adds two flashes of led 31 which is 1,0,0,0,0 which I can't see the reason for?
struct LED {
byte reg; // shift register index 0..4
byte bit; // bit position 0..7
// define LEDs by which register and which bit
const LED leds[] = {
// {0,0},{0,0},{0,0},{0,0},{0,0}, // placeholders 0–4
{2,2}, {2,3}, {2,4}, {2,5}, {2,6},
{2,7}, {4,0}, {4,1}, {4,2}, {4,3},
{4,4}, {4,5}, {1,2}, {1,3}, {4,6},
{4,7}, {3,0}, {3,1}, {1,4}, {1,5},
{1,6}, {1,7}, {3,2}, {3,3}, {3,4},
{3,5}, {0,0}, {0,1}, {0,2}, {0,3},
{3,6}, {3,7}, {2,0}, {2,1}, {0,4},
{0,5}
byte shadow[] = {0,0,0,0,0};
void setLED(int pinNumber, bool state) {
LED l = leds[pinNumber];
if(state) shadow[l.reg] |= (1 << l.bit);
else shadow[l.reg] &= ~(1 << l.bit);
for(int i = 0; i < 5; i++) shiftOut(dataPin, clockPin, MSBFIRST, shadow[i]);
for(int i = 0; i < 41; i++)
setLED(i, HIGH);
delay(100);
setLED(i, LOW);
delay(30);
gcjr, thanks, that looks even longer ![]()
