How do I use xbeewithcallbacks inside class
I am trying to figure out how to use XbeeWithCallbacks inside of a class. I am a very experanced programmer, but for the life of me I can not get this working. I am using Xbee.h.
Example in .ini code
// Object that handles the xbee objects XBeeWithCallbacks Xbee;
void setup() { // setting of your Xbee. SerialXbee.begin(9600); // Start up the xbee Xbee.begin(SerialXbee); }
Then: Class foo { public: foo(XBeeWithCallbacks vXbee); XBeeWithCallbacks Xbee; test(); }
Foo:Foo(XBeeWithCallbacks vXbee) { Xbee = vXbee; } Foo::test() { Xbee.sendAtCommand(Command); }
The test function is complete and long so I did not post everything here. It basically says the radio is not connecting. I can get this to work no problem on the .ino file. Any help would be appreciated thanks, Donald Boissonneault
The amount of help you will get is commensurate with the amount of code you post.
The code does something which you are keeping secret. You expect the code to do something which you are keeping a secret.
I'll keep the solution a secret, too, then.
