How do I wire bidirectional switch to a DC motor (that has an extra direction wire)
Hi all,
I'm trying to rebuild a prototype braiding machine which has an Arduino driving a number of servos + a central DC motor gear. The original DC motor was not encoded (2 wires only), so it could be directionally controlled to a bidirectional switch directly hooked up to the power supply (was not connected to Arduino wiring).
The replacement DC motor I have has 5 wires (spec sheet here), and I'm trying to figure out the logic of how to connect the motor to the switch with the extra directional wire. If I hook up VCC and GND to the switch, that will only drive the motor in one direction. I don't need to control speed (only direction) so the wiring should stay separate from the Arduino components.
Rough sketch of wiring
How can I also get it to reverse with the switch?
Any help would be appreciated!
Here's a bonus photo of one previous iteration of this machine
But you'll have to turn it on/off I suppose?
The motor has a built-in H-bridge. For direction change you switch the CW/CCW wire lo/hi. For run/stop you can either switch motor power on/off or switch PWM control hi/lo.
You can have full left/stop/right control with a Double Pole Triple Throw (DP3T) switch.
