How do i write in my serial monitor data into the SD card text file
Here is my Receiver end of the code.
#include <SoftwareSerial.h>
#include <SPI.h>
#include <SD.h>
File myFile;
SoftwareSerial mySerial(2, 3); // TX, RX
   // Open port for communication
   mySerial.begin(115200);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
    Serial.print("Initializing SD card...");
    if (!SD.begin(10)) {
    Serial.println("initialization failed!");
    while (1);
    Serial.println("initialization done.");
    // open the file. note that only one file can be open at a time,
    // so you have to close this one before opening another.
    myFile = SD.open("test.txt", FILE_WRITE);
    // if the file opened okay, write to it:
    if (myFile) {
    Serial.print("Writing to test.txt...");
    Serial.println(mySerial.read());
    myFile.write(mySerial.read());
    // close the file:
    myFile.close();
    Serial.println("done.");
    if (mySerial.available())
    Serial.write(mySerial.read()); // if it receives a message, displays it on the serial monitor
However my sd card txt file displays an unknown character.
Here is my Transmitting end of the code.
#include <SoftwareSerial.h> //Used for transmitting to the device
SoftwareSerial softSerial(2, 3); //RX, TX
SoftwareSerial mySerial(5, 6); // TX, RX
#include "SparkFun_UHF_RFID_Reader.h" //Library for controlling the M6E Nano module
RFID nano; //Create instance
  while (!Serial); //Wait for the serial port to come online
  if (setupNano(38400) == false) //Configure nano to run at 38400bps
    Serial.println(F("Module failed to respond. Please check wiring."));
    while (1); //Freeze!
  nano.setRegion(REGION_OPEN); //Set to North America
  nano.setReadPower(2300); //5.00 dBm. Higher values may caues USB port to brown out
  //Max Read TX Power is 27.00 dBm and may cause temperature-limit throttling
  Serial.println(F("Press a key to begin scanning for tags."));
  while (!Serial.available()); //Wait for user to send a character
  Serial.read(); //Throw away the user's character
  nano.startReading(); //Begin scanning for tags
  if (nano.check() == true) //Check to see if any new data has come in from module
    byte responseType = nano.parseResponse(); //Break response into tag ID, RSSI, frequency, and timestamp
    if (responseType == RESPONSE_IS_KEEPALIVE)
      Serial.println(F("Scanning"));
    else if (responseType == RESPONSE_IS_TAGFOUND)
      //If we have a full record we can pull out the fun bits
      int rssi = nano.getTagRSSI(); //Get the RSSI for this tag read
      long freq = nano.getTagFreq(); //Get the frequency this tag was detected at
      long timeStamp = nano.getTagTimestamp(); //Get the time this was read, (ms) since last keep-alive message
      byte tagEPCBytes = nano.getTagEPCBytes(); //Get the number of bytes of EPC from response
      Serial.print(F(" rssi["));
      Serial.print(rssi);
      Serial.print(F("]"));
      Serial.print(F(" freq["));
      Serial.print(freq);
      Serial.print(F(" time["));
      Serial.print(timeStamp);
      mySerial.print(" rssi");
      mySerial.print(rssi);
      mySerial.print(F("]"));
      mySerial.print(F(" freq["));
      mySerial.print(freq);
      mySerial.print(F(" timestamp["));
      mySerial.print(timeStamp);
      mySerial.println(F("]"));
    else if (responseType == ERROR_CORRUPT_RESPONSE)
      Serial.println("Bad CRC");
      //Unknown response
      Serial.print("Unknown error");
//Gracefully handles a reader that is already configured and already reading continuously
//Because Stream does not have a .begin() we have to do this outside the library
boolean setupNano(long baudRate)
  nano.begin(softSerial); //Tell the library to communicate over software serial port
  //Test to see if we are already connected to a module
  //This would be the case if the Arduino has been reprogrammed and the module has stayed powered
  softSerial.begin(baudRate); //For this test, assume module is already at our desired baud rate
  while (softSerial.isListening() == false); //Wait for port to open
  //About 200ms from power on the module will send its firmware version at 115200. We need to ignore this.
  while (softSerial.available()) softSerial.read();
  nano.getVersion();
  if (nano.msg[0] == ERROR_WRONG_OPCODE_RESPONSE)
    //This happens if the baud rate is correct but the module is doing a ccontinuous read
    nano.stopReading();
    Serial.println(F("Module continuously reading. Asking it to stop..."));
    delay(1500);
    //The module did not respond so assume it's just been powered on and communicating at 115200bps
    softSerial.begin(115200); //Start software serial at 115200
    nano.setBaud(baudRate); //Tell the module to go to the chosen baud rate. Ignore the response msg
    softSerial.begin(baudRate); //Start the software serial port, this time at user's chosen baud rate
    delay(250);
  //Test the connection
  nano.getVersion();
  if (nano.msg[0] != ALL_GOOD) return (false); //Something is not right
  //The M6E has these settings no matter what
  nano.setTagProtocol(); //Set protocol to GEN2
  nano.setAntennaPort(); //Set TX/RX antenna ports to 1
  return (true); //We are ready to rock
i see you print one character and then write the NEXT character to the SD card. Why?
takes one character out of the serial receive-buffer and then prints it.
After printing the character is gone forever.
If you want this character to be printed and safed to your SD-card
You have to store the character in a variable and then use the variable for all operations
above setup declare
char myCh;
inside your function
  myCh = mySerial.read();  // take character out of serial receivebuffer AND store into a variable
  Serial.println(myCh); // use variable to print the character
  myFile.write(myCh); // use variable to store the character on SD-card
best regards Stefan
2 problems here. 1) You are assuming there is at least one byte in the mySerial receive buffer. 2) You call mySerial.read() two times.
If there is no byte in the receive buffer then mySerial.read() will return -1 which is interpreted as ASCII 255 (0xff) which will print as ÿ.
Hi paul, this is just an indicator to show that the receiver side is actually running.
Hi Stefan, i tried implementing your soln into my program. However the txt output is still the same.
#include <SPI.h>
#include <SD.h>
char myCh;
File myFile;
   while (!Serial) {
    while (1);
    myCh= mySerial.read();
    if (myFile) {
    myFile.write(myCh);
    // close the file:
    myFile.close();
    Serial.write(myCh); // if it receives a message, displays it on the serial monitor
Have you read this?
