Hi, I want to write bit RUNSTDBY in CNTRLA register for TC.
Shouldn't be too hard should it? Then why have I spent the last five hours running around in circles? The data sheet might as well be written in Chinese!
I am trying to get the TC to work in sleep walking mode.
before I go to sleep() I set the following registers:
SYSCTRL->VREG.reg |= 0x40; // RUNSTDBY for voltage regulator
while(!SYSCTRL->PCLKSR.reg & 0x01); //Before writing to any of the DFLL48M control registers, the user must check that the DFLL Ready bit (PCLKSR.DFLLRDY) in PCLKSR is set to one.
SYSCTRL->DFLLCTRL.reg |= 0x40; // RUNSTDBY for DFLL48
???????????????->CTRLA.reg |= 0x0800; // RUNSTDBY for TC
How do I address the TC periferal? ie what do I put where the question marks are?
There should be a list of all the register macros somewhere. Anyone know where that would be? Can you imagine how frustrating it is not being able to do something so fundamentally basic. Insert expletive here!
Which TC? There can be up to 5 (numbered TC3 - TC7). There appear to be 3 implemented in the version of SAMD21 used on the Adafruit Feather M0 (TC3 - TC5). Which mode; 8, 16, 32 bit?
From the core for the Adafruit board, for example, use:
TC3->COUNT32.CTRLA.bit.RUNSTDBY = 1;
Not sure if different for other boards that use SAMD21.
I found all this in 'samd21g18a.h'.
EDIT:
Some of the definitions are in 'tc.h'.
EDIT #2:
If you absolutely had to, you could always go rogue:
volatile uint16_t * const TC3_CTRLA = (volatile uint16_t *) 0x42002C00;
(*TC3_CTRLA) |= 0x0080;
Thank you so much gfvalvo, I've learned a lot from your contribution. I had tried TC4->CNTRLA.reg=0x0800 but got a compile error "Tc* has no member CNTRLA".
Thanks for showing me the samd21ga.h file. I found it in CMSIS-Atmel.
I can't find the definition for the structures COUNT8, COUNT16, COUNT32 in either tc.h or samd21ga.h
would you know where to find them?
Thanks again, I will press the feed bar (add karma) many times.
In my installation, it's at the end of tc.h:
/** \brief TC_COUNT8 hardware registers */
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
typedef struct { /* 8-bit Counter Mode */
__IO TC_CTRLA_Type CTRLA; /**< \brief Offset: 0x00 (R/W 16) Control A */
__IO TC_READREQ_Type READREQ; /**< \brief Offset: 0x02 (R/W 16) Read Request */
__IO TC_CTRLBCLR_Type CTRLBCLR; /**< \brief Offset: 0x04 (R/W 8) Control B Clear */
__IO TC_CTRLBSET_Type CTRLBSET; /**< \brief Offset: 0x05 (R/W 8) Control B Set */
__IO TC_CTRLC_Type CTRLC; /**< \brief Offset: 0x06 (R/W 8) Control C */
RoReg8 Reserved1[0x1];
__IO TC_DBGCTRL_Type DBGCTRL; /**< \brief Offset: 0x08 (R/W 8) Debug Control */
RoReg8 Reserved2[0x1];
__IO TC_EVCTRL_Type EVCTRL; /**< \brief Offset: 0x0A (R/W 16) Event Control */
__IO TC_INTENCLR_Type INTENCLR; /**< \brief Offset: 0x0C (R/W 8) Interrupt Enable Clear */
__IO TC_INTENSET_Type INTENSET; /**< \brief Offset: 0x0D (R/W 8) Interrupt Enable Set */
__IO TC_INTFLAG_Type INTFLAG; /**< \brief Offset: 0x0E (R/W 8) Interrupt Flag Status and Clear */
__I TC_STATUS_Type STATUS; /**< \brief Offset: 0x0F (R/ 8) Status */
__IO TC_COUNT8_COUNT_Type COUNT; /**< \brief Offset: 0x10 (R/W 8) COUNT8 Counter Value */
RoReg8 Reserved3[0x3];
__IO TC_COUNT8_PER_Type PER; /**< \brief Offset: 0x14 (R/W 8) COUNT8 Period Value */
RoReg8 Reserved4[0x3];
__IO TC_COUNT8_CC_Type CC[2]; /**< \brief Offset: 0x18 (R/W 8) COUNT8 Compare/Capture */
} TcCount8;
#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
/** \brief TC_COUNT16 hardware registers */
typedef struct { /* 16-bit Counter Mode */
__IO TC_COUNT16_COUNT_Type COUNT; /**< \brief Offset: 0x10 (R/W 16) COUNT16 Counter Value */
RoReg8 Reserved3[0x6];
__IO TC_COUNT16_CC_Type CC[2]; /**< \brief Offset: 0x18 (R/W 16) COUNT16 Compare/Capture */
} TcCount16;
/** \brief TC_COUNT32 hardware registers */
typedef struct { /* 32-bit Counter Mode */
__IO TC_COUNT32_COUNT_Type COUNT; /**< \brief Offset: 0x10 (R/W 32) COUNT32 Counter Value */
RoReg8 Reserved3[0x4];
__IO TC_COUNT32_CC_Type CC[2]; /**< \brief Offset: 0x18 (R/W 32) COUNT32 Compare/Capture */
} TcCount32;
typedef union {
TcCount8 COUNT8; /**< \brief Offset: 0x00 8-bit Counter Mode */
TcCount16 COUNT16; /**< \brief Offset: 0x00 16-bit Counter Mode */
TcCount32 COUNT32; /**< \brief Offset: 0x00 32-bit Counter Mode */
} Tc;
Thank you, I found it here:
Arduino15\packages\arduino\tools\CMSIS-Atmel\1.1.0\CMSIS\Device\ATMEL\samd21\include\component\tc.h
I have been looking at the tc.h file that was packaged with the AdafruitZeroTimer library. What a dolt!
Cheers, Thanks again.
For posterity, putting the following in setup() configures sleep walking for TC peripheral which wakes the CPU from sleep when a TC interrupt occurs.
SYSCTRL->VREG.bit.RUNSTDBY = 1; // RUNSTDBY for voltage regulator so we don't brown out.
while(!SYSCTRL->PCLKSR.bit.DFLLRDY); //Before writing to DFLL48M control registers, must check that the DFLL Ready bit (PCLKSR.DFLLRDY) in PCLKSR is set to one.
SYSCTRL->DFLLCTRL.bit.RUNSTDBY = 1; // RUNSTDBY for DFLL48
TC4->COUNT16.CTRLA.bit.RUNSTDBY = 1; //// RUNSTDBY for TC periferal
