What type is var2?
It sounds like you are planning to write a separate function to write each digit value (10) to each digit position (4), hence 40 functions. Don't do it that way
Suppose that you wrote a function to which you passed the digit position (0 - 3) and the digit to be displayed (0 - 9) then you could do it with a single function
You can split an int into separate digits like this
//split the count into single digita
data[0] = count / 1000;
data[1] = (count / 100) % 10;
data[2] = (count / 10) % 10;
data[3] = count % 10;
declare an index of an array of segments for that digit value like this
const byte segmentData[] =
0b11111100, //0
0b01100000, //1
0b11011010, //2
0b11110010, //3
0b01100110, //4
0b10110110, //5
0b10111110, //6
0b11100000, //7
0b11111110, //8
0b11110110 //9
Iterate through the data array to get each digit value then use it to look up the associated segments and turn them on
haha yes that was exactly the plan. I understand what you are telling me but I'm not there yet in my arduino lingo but I'm looking into it now. As soon as johnwasser provided a solution I opened a new can of worms just organizing the whole mess.. this topic was more about finding a solution to the current road block.
Perhaps you can elaborate on your reply.. How do I implement your code?
Regards,
I am not sure that I can add more without actually writing the code, which I think you should do
Start by writing a sketch that splits the 4 digit number into separate digits and prints them on separate lines in the Serial monitor
Once that works write a function that takes a byte of value 0 to 9 and prints the corresponding entry in the segmentData array in binary. Call that from your first sketch. You should see a 1 for each segment that needs to be on and 0 for the others.
Using the bitRead() function you can iterate through the bits and turn the associated segments on or off
