How do led strip contollers with music mode
How do led strip controllers that react to music react to well.... music. I need functionality that typical ws2812b / sk6812 leds controllers simply cant do. Im more curious what IC / Sensor they are using and what they are looking or the sound waves, Is the controller doing frequency analysis? though i doubt they do it that way since that it a very processor intensive task.
Any ideas?
Yes. I've not only an idea but I've got a working project that 'listens' to music and does the led strip thing.
I used a microphone module, a DFRobot audio analyzer module, and a LED addressable LED strip.
The DFRobot auduio analyzer is doing the frequency sample of the audio sent to it from the microphone module. A bit of code to distribute the detected frequency and intensity levels to the led strip and it all good.
If you want I can post my code for the project.
The code is wrote for an ESP32, the audio analalyzer has been modified for an ESP32 AD converter, and I'm not going to walk you through how it works.
Idahowalker:
Sure ! i would love to see your code ! Many thanks.
May I ask what kind of data does the MSGEQ7 IC spits out and how you process it. you dont need to go into specifics just the general idea. Im trying to create a mental image of how eveything works
Well, you can enter the words "MSGEQ7" into your internet search thngy and get some results, one such result is the Seven Band Graphic Equalizer Datasheet, https://www.sparkfun.com/datasheets/Components/General/MSGEQ7.pdf. There are other results.
part i , I’ve been working to add in connecting to a MQTT Broker, you can ignore that code.
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h"
#include "sdkconfig.h"
#include "esp32/ulp.h"
#include "driver/rtc_io.h"
#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include "AudioAnalyzer.h"
/* define event group and event bits */
EventGroupHandle_t eg;
#define evtDo_AudioReadFreq       ( 1 << 0 ) // 1
QueueHandle_t xQ_LED_Info;
//const int LED_COUNT = 24; //total number of leds in the strip
const int LED_COUNT = 108; //total number of leds in the strip
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
Adafruit_NeoPixel leds = Adafruit_NeoPixel( LED_COUNT, 26, NEO_GRB + NEO_KHZ800 );
WiFiClient wifiClient;
PubSubClient MQTTclient(mqtt_server, mqtt_port, wifiClient);
SemaphoreHandle_t sema_MQTT_KeepAlive;
void ULP_BLINK_RUN(uint32_t us);
  ULP_BLINK_RUN(100000);
  eg = xEventGroupCreate();
  int FreqVal[7]; // used to set queue size
  xQ_LED_Info = xQueueCreate ( 1, sizeof(FreqVal) );
  sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive );
  // setting must be set before a mqtt connection is made
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds
  connectToWiFi();
  connectToMQTT();
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 7000, NULL, 5, NULL, 1 );
  xTaskCreatePinnedToCore( fDo_AudioReadFreq, "fDo_ AudioReadFreq", 30000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fDo_LEDs, "fDo_ LEDs", 30000, NULL, 3, NULL, 1 );
  xEventGroupSetBits( eg, evtDo_AudioReadFreq );
} // setup()
void loop() {} // void loop
void fMQTT_Disconnect(  )
  MQTTclient.disconnect();
void GetTheTime()
  char* ntpServer = "2.us.pool.ntp.org";
  int gmtOffset_sec = -(3600 * 7 );
  int daylightOffset_sec = 3600;
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
  printLocalTime();
// http://www.cplusplus.com/reference/ctime/strftime/
void MQTTkeepalive( void *pvParameters )
  int keepCount = 0;
  for (;;)
    log_i( " mqtt keep alive run." );
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      //      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); //
      MQTTclient.loop();
      //      xSemaphoreGive( sema_MQTT_KeepAlive );
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
    vTaskDelay( 4900 );
    keepCount++;
    log_i( "%d", keepCount );
    if ( keepCount >= 5 )
      fMQTT_Disconnect();
      keepCount = 0;
  vTaskDelete ( NULL );
int getHour()
  struct tm timeinfo;
  getLocalTime(&timeinfo);
  char _time[ 5 ];
  strftime( _time, 80, "%T", &timeinfo );
  return String(_time).toInt();
void printLocalTime() {
  struct tm timeinfo;
  char _time[ 80 ];
  log_i( "%s", _time);
void connectToMQTT()
  log_i( "connect to mqtt" );
  while ( !MQTTclient.connected() )
    MQTTclient.connect( clientID, mqtt_username, mqtt_password );
    log_i( "connecting to MQTT" );
    vTaskDelay( 250 );
  log_i("MQTT Connected");
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( mqtt_topic );
void connectToWiFi()
  log_i( " Begin Connect to wifi" );
  while ( WiFi.status() != WL_CONNECTED )
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    log_i(" waiting on wifi connection" );
    vTaskDelay( 4000 );
  log_i( "End connected to WiFi" );
  WiFi.onEvent( WiFiEvent );
  GetTheTime();
part2
static void mqttCallback(char* topic, byte * payload, unsigned int length)
  //xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY);
  //str_eTopicPtr = topic + '\0';
  int i = 0;
  String temp = "";
  for ( i; i < length; i++) {
    temp += ((char)payload[i]);
  log_i( " topic %s payload %s", topic, temp );
  //  strPayloadPtr[i] = '\0';
  // xSemaphoreGive ( sema_MQTT_KeepAlive );
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
void fDo_LEDs( void *pvParameters )
  const int Brightness = 200;
  const int SEG = 6; // how many parts you want to separate the led strip into
  const int ledCount = LED_COUNT; //total number of leds in the strip
  int iFreqVal[7];
  int j;
  leds.begin(); // Call this to start up the LED strip.
  clearLEDs( ledCount );  // This function, defined below, de-energizes all LEDs...
  leds.show();  // ...but the LEDs don't actually update until you call this.
  leds.setBrightness( Brightness ); //  1 = min brightness (off), 255 = max brightness.
  for (;;)
    if (xQueueReceive( xQ_LED_Info, &iFreqVal,  portMAX_DELAY) == pdTRUE)
      j = 0;
      //assign different values for different parts of the led strip
      for (j = 0; j < ledCount; j++)
        if ( (0 <= j) && (j < (ledCount / SEG)) )
          //log_i( "segment 0 %d", iFreqVal[0] );
          set( j, iFreqVal[0], ledCount, SEG ); // set the color of led
        else if ( ((ledCount / SEG) <= j) && (j < (ledCount / SEG * 2)) )
        else if ( ((ledCount / SEG * 2) <= j) && (j < (ledCount / SEG * 3)) )
        else if ( ((ledCount / SEG * 3) <= j) && (j < (ledCount / SEG * 4)) )
        else if ( ((ledCount / SEG * 4) <= j) && (j < (ledCount / SEG * 5)) )
      leds.show();
  vTaskDelete( NULL );
} // void fDo_ LEDs( void *pvParameters )
void fDo_AudioReadFreq( void *pvParameters )
  int FreqVal[7];
  const int NOISE = 10; // noise that you want to chop off
  const int A_D_ConversionBits = 4096; // arduino use 1024, ESP32 use 4096
  Analyzer Audio = Analyzer( 5, 15, 36 );//Strobe pin ->15  RST pin ->2 Analog Pin ->36
  Audio.Init(); // start the audio analyzer
  int64_t EndTime = esp_timer_get_time();
  int64_t StartTime = esp_timer_get_time(); //gets time in uSeconds like Arduino Micros
  for (;;)
    xEventGroupWaitBits (eg, evtDo_AudioReadFreq, pdTRUE, pdTRUE, portMAX_DELAY);
    EndTime = esp_timer_get_time() - StartTime;
    // log_i( "TimeSpentOnTasks: %d", EndTime );
    Audio.ReadFreq(FreqVal);
    for (int i = 0; i < 7; i++)
      FreqVal[i] = constrain( FreqVal[i], NOISE, A_D_ConversionBits );
      FreqVal[i] = map( FreqVal[i], NOISE, A_D_ConversionBits, 0, 255 );
      // log_i( "Freq %d Value: %d", i, FreqVal[i]);//used for debugging and Freq choosing
    xQueueSend( xQ_LED_Info, ( void * ) &FreqVal, 0 );
} // fDo_ AudioReadFreq( void *pvParameters )
//the following function set the led color based on its position and freq value
void set(byte position, int value, int ledCount, int segment)
  int valueLowLimit = 20;
  // segment 0, red
  if ( (0 <= position) && (position < ledCount / segment) ) // segment 0 (bottom to top)
    if ( value <= valueLowLimit )
      leds.setPixelColor( position, 0, 0, 0 );
      leds.setPixelColor( position, leds.Color( value , 0, 0) );
  else if ( (ledCount / segment <= position) && (position < ledCount / segment * 2) ) // segment 1 yellow
      leds.setPixelColor(position, leds.Color(0, 0, 0));
      leds.setPixelColor(position, leds.Color( value, value, 0)); // works better to make yellow
  else if ( (ledCount / segment * 2 <= position) && (position < ledCount / segment * 3) ) // segment 2 pink
      leds.setPixelColor(position, leds.Color( value, 0, value * .91) ); // pink
  else if ( (ledCount / segment * 3 <= position) && (position < ledCount / segment * 4) ) // seg 3, green
      leds.setPixelColor(position, leds.Color( 0, 0, 0));
    else //
      leds.setPixelColor( position, leds.Color( 0, value, 0) ); //
  else if ( (ledCount / segment * 4 <= position) && (position < ledCount / segment * 5) ) // segment 4, leds.color( R, G, B ), blue
    else //
      leds.setPixelColor(position, leds.Color( 0, 0, value) ); // blue
  else // segment 5
      leds.setPixelColor( position, leds.Color( value, value * .3, 0) ); // orange
} // void set(byte position, int value)
part 3
void clearLEDs( int ledCount)
  for (int i = 0; i < ledCount; i++)
    leds.setPixelColor(i, 0);
} // void clearLEDs()
void WiFiEvent(WiFiEvent_t event)
  // log_i( "[WiFi-event] event: %d\n", event );
  switch (event)
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
  Each I_XXX preprocessor define translates into a single 32-bit instruction. So you can count instructions to learn which memory address are used and where the free mem space starts.
  To generate branch instructions, special M_ preprocessor defines are used. M_LABEL define can be used to define a branch target.
  Implementation note: these M_ preprocessor defines will be translated into two ulp_insn_t values: one is a token value which contains label number, and the other is the actual instruction.
  size_t load_addr = 0;
  RTC_SLOW_MEM[12] = 0;
  ulp_set_wakeup_period(0, us);
  const ulp_insn_t  ulp_blink[] =
    I_MOVI(R3, 12),                         // #12 -> R3
    I_LD(R0, R3, 0),                        // R0 = RTC_SLOW_MEM[R3(#12)]
    M_BL(1, 1),                             // GOTO M_LABEL(1) IF R0 < 1
    I_WR_REG(RTC_GPIO_OUT_REG, 26, 27, 1),  // RTC_GPIO2 = 1
    I_SUBI(R0, R0, 1),                      // R0 = R0 - 1, R0 = 1, R0 = 0
    I_ST(R0, R3, 0),                        // RTC_SLOW_MEM[R3(#12)] = R0
    M_BX(2),                                // GOTO M_LABEL(2)
    M_LABEL(1),                             // M_LABEL(1)
    I_WR_REG(RTC_GPIO_OUT_REG, 26, 27, 0),// RTC_GPIO2 = 0
    I_ADDI(R0, R0, 1),                    // R0 = R0 + 1, R0 = 0, R0 = 1
    M_LABEL(2),                             // M_LABEL(2)
    I_HALT()                                // HALT COPROCESSOR
  const gpio_num_t led_gpios[] =
    GPIO_NUM_2,
    // GPIO_NUM_0,
    // GPIO_NUM_4
  for (size_t i = 0; i < sizeof(led_gpios) / sizeof(led_gpios[0]); ++i) {
    rtc_gpio_init(led_gpios[i]);
    rtc_gpio_set_direction(led_gpios[i], RTC_GPIO_MODE_OUTPUT_ONLY);
    rtc_gpio_set_level(led_gpios[i], 0);
  size_t size = sizeof(ulp_blink) / sizeof(ulp_insn_t);
  ulp_process_macros_and_load( load_addr, ulp_blink, &size);
  ulp_run( load_addr );
} // void ULP_BLINK_RUN(uint32_t us)
You can ignore the MQTT parts.
Good luck
I've done several sound activated lighting effects, but nothing with addressable RGB LED strips. Everything I've done just uses the volume (and some very-crude "beat detection"). I've thought about doing something with the MSGEQ7 and/or with addressable strips but as it is now, I have enough randomized variations that I can run for hours without seeing all of the effects/options. ...A long time ago I made a "color organ" (which has one color for each of 3 or 4 frequency bands) but I got bored with it.
I use a direct line-level audio input (like from the audio jacks on a CD/DVD player or from your TV, etc.) into a Peak Detector (AKA Envelope Follower). (A headphone connection is about the same voltage so it works too.)
The peak detector allows me to sample the "loudness" about 10 times per second instead of sampling the actual waveform thousands of times per second. But, you loose all of the frequency information.
Since the MSGEQ7 takes care of the frequency filtering/analysis it can also run relatively slowly, allowing your code to spend more time running the LEDs.
The MSGEQ7 puts-out 7 [u]multiplexed[/u] analog DC voltages representing the amplitude of the 7 frequency bands, so you read the 7 frequency bands with just one analog input. First it puts-out the lowest frequency (bass) and then after the next clock (STROBE) it puts-out a voltage representing the next frequency banc, etc. When it gets to the end, you send an RESET to start the sequence over again. ...That's the basic concept and the timing diagram at the bottom of the datasheet shows exactly how to control it.
Just to get started check out my [u]World's Simplest Lighting Effect[/u]. It uses a biased input (2 resistors and a capacitor) instead of a peak detector and it uses the built-in LED, so it takes very little hardware. I've also tested it with a SparkFun microphone board (BOB 12758) but the sound has to be slightly-loud (a little louder than I normally listen to the TV). The microphone board already has a biased output.
It takes a 20 second moving average so it automatically adjusts to volume changes. You might want to steal that concept. All of my real effects do that, and some of the effects use the peak as a reference. (Since I'm only saving a "random" sample once per second it's the necessarily THE peak, but it's A peak that can be useful. And, my "average" is actually an average-of-peaks.)
The other thing I do in my real effects to handle a wider range of levels is automatically switch between the 1.1V and 5V ADC references, depending on the data in the 20-second array. (All of the data in the array has be re-scaled whenever I switch.) That will work with a peak detector and it should work with the MSGEQ7 but of course you can't use the 1.1V reference if you bias the input at 2.5V.
