How do use 3 sketches on one Arduino
I have a Arduino Uno, BMP180, Geiger counter, and a Ultimate GPS Data logger shield. I have all the codes working but I don’t have any clue how to combine then to use then all as one.
BMP
#include <Wire.h>
#define ADDRESS_SENSOR 0x77                 // Sensor address
int16_t  ac1, ac2, ac3, b1, b2, mb, mc, md; // Store sensor PROM values from BMP180
uint16_t ac4, ac5, ac6;                     // Store sensor PROM values from BMP180
// Ultra Low Power       OSS = 0, OSD =  5ms
// Standard              OSS = 1, OSD =  8ms
// High                  OSS = 2, OSD = 14ms
// Ultra High Resolution OSS = 3, OSD = 26ms
const uint8_t oss = 3;                      // Set oversampling setting
const uint8_t osd = 26;                     // with corresponding oversampling delay
float T, P;                                 // Set global variables for temperature and pressure
  Wire.begin();                             // Activate I2C
  Serial.begin(9600);                       // Set up serial port
  init_SENSOR();                            // Initialize baro sensor variables
  delay(100);
  int32_t b5;
  b5 = temperature();                       // Read and calculate temperature (T)
  Serial.print("Temperature: ");
  Serial.print(T, 2);
  Serial.print(" C, ");
  Serial.print(1.8 * T + 32.0, 2);
  Serial.println(" F");
  P = pressure(b5);                         // Read and calculate pressure (P)
  Serial.print("Pressure: ");
  Serial.print(P, 2);
  Serial.print(" mbar, ");
  Serial.print(P * 0.0295299830714, 2);
  Serial.println(" inHg");
  Serial.println("");
  delay(500);                               // Delay between each readout
  Initialize sensor variables
void init_SENSOR()
  ac1 = read_2_bytes(0xAA);
  ac2 = read_2_bytes(0xAC);
  ac3 = read_2_bytes(0xAE);
  ac4 = read_2_bytes(0xB0);
  ac5 = read_2_bytes(0xB2);
  ac6 = read_2_bytes(0xB4);
  b1  = read_2_bytes(0xB6);
  b2  = read_2_bytes(0xB8);
  mb  = read_2_bytes(0xBA);
  mc  = read_2_bytes(0xBC);
  md  = read_2_bytes(0xBE);
  Serial.println("");
  Serial.println("Sensor calibration data:");
  Serial.print(F("AC1 = ")); Serial.println(ac1);
  Serial.print(F("AC2 = ")); Serial.println(ac2);
  Serial.print(F("AC3 = ")); Serial.println(ac3);
  Serial.print(F("AC4 = ")); Serial.println(ac4);
  Serial.print(F("AC5 = ")); Serial.println(ac5);
  Serial.print(F("AC6 = ")); Serial.println(ac6);
  Serial.print(F("B1 = "));  Serial.println(b1);
  Serial.print(F("B2 = "));  Serial.println(b2);
  Serial.print(F("MB = "));  Serial.println(mb);
  Serial.print(F("MC = "));  Serial.println(mc);
  Serial.print(F("MD = "));  Serial.println(md);
  Serial.println("");
  Calcualte pressure readings
float pressure(int32_t b5)
  int32_t x1, x2, x3, b3, b6, p, UP;
  uint32_t b4, b7;
  UP = read_pressure();                         // Read raw pressure
  b6 = b5 - 4000;
  x1 = (b2 * (b6 * b6 >> 12)) >> 11;
  x2 = ac2 * b6 >> 11;
  x3 = x1 + x2;
  b3 = (((ac1 * 4 + x3) << oss) + 2) >> 2;
  x1 = ac3 * b6 >> 13;
  x2 = (b1 * (b6 * b6 >> 12)) >> 16;
  x3 = ((x1 + x2) + 2) >> 2;
  b4 = (ac4 * (uint32_t)(x3 + 32768)) >> 15;
  b7 = ((uint32_t)UP - b3) * (50000 >> oss);
  if(b7 < 0x80000000) { p = (b7 << 1) / b4; } else { p = (b7 / b4) << 1; } // or p = b7 < 0x80000000 ? (b7 * 2) / b4 : (b7 / b4) * 2;
  x1 = (p >> 8) * (p >> 8);
  x1 = (x1 * 3038) >> 16;
  x2 = (-7357 * p) >> 16;
  return (p + ((x1 + x2 + 3791) >> 4)) / 100.0f; // Return pressure in mbar
  Read uncompensated temperature
int32_t temperature()
  int32_t x1, x2, b5, UT;
  Wire.beginTransmission(ADDRESS_SENSOR); // Start transmission to device
  Wire.write(0xf4);                       // Sends register address
  Wire.write(0x2e);                       // Write data
  Wire.endTransmission();                 // End transmission
  delay(5);                               // Datasheet suggests 4.5 ms
  UT = read_2_bytes(0xf6);                // Read uncompensated TEMPERATURE value
  // Calculate true temperature
  x1 = (UT - (int32_t)ac6) * (int32_t)ac5 >> 15;
  x2 = ((int32_t)mc << 11) / (x1 + (int32_t)md);
  b5 = x1 + x2;
  T  = (b5 + 8) >> 4;
  T = T / 10.0;                           // Temperature in celsius
  return b5;
  Read uncompensated pressure value
int32_t read_pressure()
  int32_t value;
  Wire.write(0xf4);                         // Sends register address to read from
  Wire.write(0x34 + (oss << 6));            // Write data
  Wire.endTransmission();                   // SEd transmission
  delay(osd);                               // Oversampling setting delay
  Wire.write(0xf6);                         // Register to read
  Wire.requestFrom(ADDRESS_SENSOR, 3);      // Request three bytes
  if(Wire.available() >= 3)
    value = (((int32_t)Wire.read() << 16) | ((int32_t)Wire.read() << 8) | ((int32_t)Wire.read())) >> (8 - oss);
  return value;                             // Return value
  Read 1 byte from the BMP sensor
uint8_t read_1_byte(uint8_t code)
  uint8_t value;
  Wire.write(code);                               // Sends register address to read from
  Wire.requestFrom(ADDRESS_SENSOR, 1);            // Request data for 1 byte to be read
  if(Wire.available() >= 1)
    value = Wire.read();                          // Get 1 byte of data
  Read 2 bytes from the BMP sensor
uint16_t read_2_bytes(uint8_t code)
  uint16_t value;
  Wire.requestFrom(ADDRESS_SENSOR, 2);            // Request 2 bytes from device
  if(Wire.available() >= 2)
    value = (Wire.read() << 8) | Wire.read();     // Get 2 bytes of data
Geiger counter- sorry codes are to big to send together
#include <SD.h>
#include <SPI.h>
#define LOG_PERIOD 15000     //Logging period in milliseconds, recommended value 15000-60000.
#define MAX_PERIOD 60000    //Maximum logging period
unsigned long counts;             //variable for GM Tube events
unsigned long cpm;                 //variable for CPM
unsigned int multiplier;             //variable for calculation CPM in this sketch
unsigned long previousMillis;      //variable for time measurement
void tube_impulse(){               //procedure for capturing events from Geiger Kit
  counts++;
void setup(){                                               //setup procedure
  counts = 0;
  cpm = 0;
  multiplier = MAX_PERIOD / LOG_PERIOD;      //calculating multiplier, depend on your log period
  Serial.begin(9600);                                    // start serial monitor
 // uncommennt if you have time-out problem to connect with Radiation Logger
 //  delay(2000);
 //  Serial.write('0');                                      // sending zero to avoid connection time out with radiation logger
 //  delay(2000);
  pinMode(2, INPUT);                                   // set pin INT0 input for capturing GM Tube events
  digitalWrite(2, HIGH);                                 // turn on internal pullup resistors, solder C-INT on the PCB
  attachInterrupt(0, tube_impulse, FALLING);  //define external interrupts
void loop(){                                               //main cycle
  if(currentMillis - previousMillis > LOG_PERIOD){
    cpm = counts * multiplier;
        Serial.print(cpm);                              // send cpm data to Radiation Logger
        Serial.write(' ');                                // send null character to separate next data
    counts = 0;
Option one, learn how to program and make a single sketch to do it. Aka, writing your own code for real.
Option two, pay somebody to do it for you :)
sd card for the shield
#include <SPI.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include <avr/sleep.h>
// Ladyada's logger modified by Bill Greiman to use the SdFat library
// This code shows how to listen to the GPS module in an interrupt
// which allows the program to have more 'freedom' - just parse
// when a new NMEA sentence is available! Then access data when
// desired.
// Tested and works great with the Adafruit Ultimate GPS Shield
// using MTK33x9 chipset
//    ------> http://www.adafruit.com/products/
// Pick one up today at the Adafruit electronics shop
// and help support open source hardware & software! -ada
// Fllybob added 10 sec logging option
SoftwareSerial mySerial(8, 7);
Adafruit_GPS GPS(&mySerial);
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences
#define GPSECHO  true
/* set to true to only log to SD when GPS has a fix, for debugging, keep it false */
#define LOG_FIXONLY false
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
// Set the pins used
#define chipSelect 10
#define ledPin 13
File logfile;
// read a Hex value and return the decimal equivalent
uint8_t parseHex(char c) {
  if (c < '0')
    return 0;
  if (c <= '9')
    return c - '0';
  if (c < 'A')
    return 0;
  if (c <= 'F')
    return (c - 'A')+10;
// blink out an error code
void error(uint8_t errno) {
  if (SD.errorCode()) {
   putstring("SD error: ");
   Serial.print(card.errorCode(), HEX);
   Serial.print(',');
   Serial.println(card.errorData(), HEX);
  while(1) {
    uint8_t i;
    for (i=0; i<errno; i++) {
      digitalWrite(ledPin, HIGH);
      delay(100);
      digitalWrite(ledPin, LOW);
      delay(100);
    for (i=errno; i<10; i++) {
      delay(200);
  // for Leonardos, if you want to debug SD issues, uncomment this line
  // to see serial output
  //while (!Serial);
  // connect at 115200 so we can read the GPS fast enough and echo without dropping chars
  // also spit it out
  Serial.println("\r\nUltimate GPSlogger Shield");
  pinMode(ledPin, OUTPUT);
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  //if (!SD.begin(chipSelect, 11, 12, 13)) {
    if (!SD.begin(chipSelect)) {      // if you're using an UNO, you can use this line instead
    Serial.println("Card init. failed!");
    error(2);
  char filename[15];
  strcpy(filename, "GPSLOG00.TXT");
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = '0' + i/10;
    filename[7] = '0' + i%10;
    // create if does not exist, do not open existing, write, sync after write
    if (! SD.exists(filename)) {
  logfile = SD.open(filename, FILE_WRITE);
  if( ! logfile ) {
    Serial.print("Couldnt create ");
    Serial.println(filename);
    error(3);
  Serial.print("Writing to ");
  // connect to the GPS at the desired rate
  GPS.begin(9600);
  // uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
  // uncomment this line to turn on only the "minimum recommended" data
  //GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
  // For logging data, we don't suggest using anything but either RMC only or RMC+GGA
  // to keep the log files at a reasonable size
  // Set the update rate
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);   // 100 millihertz (once every 10 seconds), 1Hz or 5Hz update rate
  // Turn off updates on antenna status, if the firmware permits it
  GPS.sendCommand(PGCMD_NOANTENNA);
  // the nice thing about this code is you can have a timer0 interrupt go off
  // every 1 millisecond, and read data from the GPS for you. that makes the
  // loop code a heck of a lot easier!
  useInterrupt(true);
  Serial.println("Ready!");
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
  char c = GPS.read();
  // if you want to debug, this is a good time to do it!
  #ifdef UDR0
      if (GPSECHO)
        if (c) UDR0 = c;
      // writing direct to UDR0 is much much faster than Serial.print
      // but only one character can be written at a time.
  #endif
void useInterrupt(boolean v) {
  if (v) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
    usingInterrupt = true;
  else {
    // do not call the interrupt function COMPA anymore
    TIMSK0 &= ~_BV(OCIE0A);
  if (! usingInterrupt) {
    // read data from the GPS in the 'main loop'
    if (GPSECHO)
      if (c) Serial.print(c);
  // if a sentence is received, we can check the checksum, parse it...
  if (GPS.newNMEAreceived()) {
    // a tricky thing here is if we print the NMEA sentence, or data
    // we end up not listening and catching other sentences!
    // so be very wary if using OUTPUT_ALLDATA and trying to print out data
    // Don't call lastNMEA more than once between parse calls!  Calling lastNMEA
    // will clear the received flag and can cause very subtle race conditions if
    // new data comes in before parse is called again.
    char *stringptr = GPS.lastNMEA();
    if (!GPS.parse(stringptr))   // this also sets the newNMEAreceived() flag to false
      return;  // we can fail to parse a sentence in which case we should just wait for another
    // Sentence parsed!
    Serial.println("OK");
    if (LOG_FIXONLY && !GPS.fix) {
      Serial.print("No Fix");
      return;
    // Rad. lets log it!
    Serial.println("Log");
    uint8_t stringsize = strlen(stringptr);
    if (stringsize != logfile.write((uint8_t *)stringptr, stringsize))    //write the string to the SD file
        error(4);
    if (strstr(stringptr, "RMC") || strstr(stringptr, "GGA"))   logfile.flush();
/* End code */
Hi, a clue plus is on THIS Page
Perhaps check these links out-
Planning and Implementing a Program Doing Multiple things at Once
The common theme among all those links is that you have to define the requirements for the resulting program BEFORE you begin cutting and pasting. We have no evidence that you've done that.
